pinto |
Post Reply | Page 123> |
fordpower
Posted: 08-December-2015 at 3:04PM |
Removed the fuel cell yesterday.It was full of water between steel shell and inner cell.Must have been condensation.Outer shell rusted through.Cell rusted to outer part.It was only setting 3yr.
Sheesh. Sorry to hear that.
fordpower
Ya jazz said they sell the shell for 100. but how do you remove the inner its rusted right to the shell.
fordpower
Freed the cell.
maybe i missed something here but, i thought pintos had a regular steel gas tank just like our torinos??? all the pintos i worked on many years ago appeared to have regular steel tanks
Ranchero Fan
Safety thing. after the exploding gas tanks from rear end collision law suits?
fordpower
Your are correct.The guy I bought it from installed a jazz fuel cell.It rusted out due to moisture between cell and shell.I just wonder if I replace it with a alm.one would same thing happen.
if i'm understanding this correctly, you have a plastic fuel cell inside the metal tank, if it's sealed for the gas, can't you drill a small 1/4" hole or two in the metal tank to let moisture drain out???(before you put in a new cell)
smhj
Senior Member Joined: 01-November-2011 Location: erie pa Status: Offline Points: 266 |
A few were made out of Aluminum at work with no issues.
73MONTEGO
fordpower
Do the alm ones have the inner cell or just foam .hole idea passed my mind.
fordpower
cut out the rear end,now to find someone to help remove it.Then I can clean it up and put the 3.23 in it.Still have not found a shop near by that can change the axle to 5 by 4.5
many years ago i had my 4 lug monza axles redrilled to 5 lug
they did an excellent job! cleaned and retrued all the surfaces, shipped them back in like a week! just make sure you specify stock lug studs or you'll get those 4" long racing studs http://www.moserengineering.com/moser/shop-services/ Edited by californiajohnny - 19-December-2015 at 2:30PM |
fordpower
Thanks for the tip.Will try after Christmas.
fordpower
Ready to put the cowl back on.There are 32 spot welds along the window area.should I glue it or attempt to weld it again.I am not a pro. welder.My concern is structure.
did you only drill the outer cowl piece regarding the spot welds? i'd weld it back in the spot weld hole, that's often referred to as "plug welding"
fordpower
Welded cowl on. Non gas wire feed is splatter crazy. Welds look bad .Does it matter which direction you go.For word or back words.
i do both, just depends on what i'm welding
fordpower
Next question anyone know were to find body measurements for body panels. I am replacing right inner fender,on unabody (sp)car it should have been part of sub frame.What I want is distance between fenders and some cross measurement from one side to other.
fordpower
Is it better to bondo to clean metal or primer?
dave302
It is better to put bondo over clean metal, not primer.
Clean metal, but it can be used over epoxy primers (DP-90, etc.)
fordpower
Thanks,soon as I buy a new grinder will get at it.
80 grit on a DA sander is fine you don't have to use a grinder unless to remove rust, 80 grit is enough "tooth" for the bondo to adhere to
dave302
There are some rims for sale for a good price, but they most likely have a 5x4.75 bolt pattern. Maybe you can have the bolt pattern drilled to a 5x4.50 bolt pattern. If you want to see them Click here.
fordpower
Needed front parking-turn sig.lens for 77pinto.
dave302
Do you need just the front left and right turn signal lenses like number 1 in the picture below? Or do you also need the side parking lights, like number 2 in the picture below?
If you want to see a front left turn signal lens for sale Click here.
Edited by dave302 - 29-February-2016 at 11:57PM |
dave302
There is a side parking light lens for sale, but the seller did not say if it will fit a 1977 model. If you want to see it Click here.
Edited by dave302 - 29-February-2016 at 10:52AM |
IIRC those front turn lenses are 76-77 specific. which side do you need? or both?
dave302
The 77 and 78 front turn signal lenses appear to be exactly the same. The 76 appears to be different. There is a picture below of a 76 lens.
There is a picture below of a 77 lens. There is a picture below of a 78 lens.
Edited by dave302 - 29-February-2016 at 3:46PM |
dave you might be right, it's been 20 years since i worked on pintos, but i remember those being a two year only thing
