  New Posts New Posts RSS Feed - cam
cam
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: cam
    Posted: 09-December-2015 at 4:26AM
Just called crane cam to find out what this car had.The spc. are 484 lift 216 duration 110 separation.So for those of us that know little what does this mean.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 09-December-2015 at 5:29AM
I just looked it up at sumett act.is 216 both adv. is more like 274 ,why the difference.,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 09-December-2015 at 12:19PM
Duration at .050 lift as opposed to total duration?
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 09-December-2015 at 2:11PM
Ok thank. Guess I'll put it back in the motor.
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 09-December-2015 at 5:13PM
That appears to be a crane 13005 cam that you have there. I will post the specs. below so that the other members can see it.
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 1,600-5,200
Intake Duration at 050 inch Lift: 216
Exhaust Duration at 050 inch Lift: 216
Advertised Intake Duration: 272
Advertised Exhaust Duration: 272
Intake Valve Lift with Factory Rocker Arm Ratio: 0.484 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.484 in.
Lobe Separation (degrees): 110
Computer-Controlled Compatible: No
Grind Number: 272 H10
Edited by dave302 - 09-December-2015 at 5:16PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 11-December-2015 at 1:08AM
according to sumett this is the highest cam for a stock 9.1 or higher 302 with stock converter.Also rec 3.5 or higher gears? I was running 2.75 with aod.?Going to 3.23 from Joe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 11-December-2015 at 1:55PM
With my Crown Vics (80s square panthers), I was MUCH happier with 3.55 rear gears and the AOD than the factory 2.73. Swapped in a 3.27 axle out of necessity which wasn't quite as much fun, but still WAY better than factory.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 11-December-2015 at 2:28PM
It appears the problem not much made for 8in rear. Jegs has 7.5 8.8 and 9 but no 8.
