  New Posts New Posts RSS Feed - windows
windows
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Topic: windows
    Posted: 01-May-2016 at 3:53AM
Will glass from power window work on reg.Parts car glass looks better than mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 01-May-2016 at 4:10AM
from power > manual will always work
power glass has a contour on the lower edge of the glass that manual does not need
true manual glass will not work with a power motor, many manual cars have power glass in them, and the wiring too. you know glass can be polished / cleaned up ... many products like this ...
probably easier & faster than R&R'ing all the windows
Edited by Rockatansky - 01-May-2016 at 4:18AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 01-May-2016 at 4:41AM
Power window glass in my '79 Ranchero has EXACTLY the same dimensions as manual glass in a pair of extra doors I have in storage(77-79 Ranchero and T-bird front door glass is also interchangeable).
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 01-May-2016 at 7:06AM
MY DRIVER GLASS IS SCRATCH FROM THE FELT. PARTS CAR LOOKS BETTER. HAVE TO DECIDE IF ITS WORTH THE WORK.
thank for info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 01-May-2016 at 1:05PM
Direct swap by 77 the glass was all the same as far as power/non-power.
minor PITA to swap... an afternoon's work.
(Less if you keep the beers to a minimum.)
Edited by Big Bird - 01-May-2016 at 1:06PM
This page was generated in 0.107 seconds.
