  New Posts New Posts RSS Feed - 73 Fastback weatherstripping
GoldFinger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GoldFinger Quote  Post ReplyReply Direct Link To This Post Topic: 73 Fastback weatherstripping
    Posted: 18-May-2016 at 3:08PM
Hello All,
Well,I have now decided to work on the weather stripping as all my weather stripping is complete garbage(all but the trunk)! Can anyone suggest which company is good to buy from, also who has the most complete weather stripping package? If there is a topic about this, sorry, I did look first before posting this. Any help would be appreciated!
DARE to be DIFFERENT!!
       73 GTS
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 18-May-2016 at 3:41PM
i got my drip rail seals and door seals from mac's (dennis carpenter) the vertical window seals are discontinued (metro) ( but i saw some on ebay 5 or 6 pair... if i can find it again i'll post it)
 and the door fuzzies i got from classtech
 i'll post some links here later
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 18-May-2016 at 6:01PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 18-May-2016 at 6:07PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 18-May-2016 at 6:21PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote GoldFinger Quote  Post ReplyReply Direct Link To This Post Posted: 18-May-2016 at 11:04PM
found them:
 http://www.ebay.com/itm/1972-76-Torino-Weatherstrip-Quarter-Window-Vertical-2dr-Hardtop-Montego-Ford-/222067553754?hash=item33b441f5da:g:ptoAAOSwy5ZXDEti&vxp=mtr
if you need these, better grab some they are discontinued!!! it says they have 6 availableBig smile
Thanks John,but these are listed for
hardtops.
       73 GTS
Compton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Compton Quote  Post ReplyReply Direct Link To This Post Posted: 26-March-2018 at 6:50PM
hey guys
need some advice regarding weatherstripping specifically repros....
got a repops beltline kit for a 73 fastback...just fitted the front door exterior pieces and am not that happy with the fit...for a start the metal strip is not as wide as the original...they also are much smaller in height so there's no protection for the glass against the outer door skin when the window is rolled down...most importantly the pre bent curve is not right on one of them so the middle of the metal trim has a 3-4mm gap to the door...
is this the general expected quality for repros or did i just get a crap kit? havent been that happy with some of the Dorman stuff either
can anyone recommend a brand of felts that is exceptional quality?
thanks
Edited by Compton - 26-March-2018 at 10:49PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 27-March-2018 at 2:05AM
I have noticed the repros are not that close to OEM. I have wondered it it would be possible to remove the new rubber window sweeps and install them on the original metal portions of the OEM window sweeps.  This might be a solution, but not sure how you'd go about doing it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Compton Quote  Post ReplyReply Direct Link To This Post Posted: 27-March-2018 at 8:07AM
Had that thought too but seeing as the rubber is formed around the metal I can't see any way of achieving it and having it last...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 28-March-2018 at 1:59PM
Yeah, I don't know how the rubber could be transferred.  I thought the aftermarket ones I have are riveted or stapled to the metal?  I'd have to dig them out of the garage to check. I am probably not going to use my set (I bought them as a in a bulk purchase) as I wasn't happy with the fitment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Compton Quote  Post ReplyReply Direct Link To This Post Posted: 28-March-2018 at 2:04PM
The Repops set are rubber moulded around the metal like original...unfortunately I don't have a choice as my original ones are toast...rubbers completely deteriorated
paj1965 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paj1965 Quote  Post ReplyReply Direct Link To This Post Posted: 12-April-2018 at 6:12AM
I'm also in the process of replacing the weatherstripping on my 72 GTS.  No luck with the quarter window vertical seal.
Does anyone know the Ford part number for these seals?
Has anyone looked into how close these seals are (lengthwise) to the seals on other cars?  i was researching this and found that D1ZZ-6330146 and 47 were used for both the 70-71 Torino fastbacks and 71-73 Mustang fastbacks.  Just wondering if they would even be close to fitting ours.
My Toy List:
1972.5 Gran Torino Sport
2001 Mustang Cobra Vert
2001 Lightning
2013 Jeep Wrangler
Post Options Post Options   Thanks (0) Thanks(0)   Quote Compton Quote  Post ReplyReply Direct Link To This Post Posted: 12-April-2018 at 7:45AM
The 70-71 seal works...it's a bit long but it can be bent back on an angle under the window and it makes no difference to the operation...
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 12-April-2018 at 11:29AM
from what i understand... the 72+ vertical seals are out of production but i've heard that 70-71 vertical seals work just fine but are a little longer at the bottomWink
Post Options Post Options   Thanks (0) Thanks(0)   Quote paj1965 Quote  Post ReplyReply Direct Link To This Post Posted: 12-April-2018 at 12:53PM
Thanks, guys!
I'm ordering a pair of the Scott Drake ones from Summit.
My Toy List:
2001 Lightning
2013 Jeep Wrangler
Power Surge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 12-April-2018 at 2:02PM
You can get the vertical seals from a company on ebay.
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote Compton Quote  Post ReplyReply Direct Link To This Post Posted: 12-April-2018 at 6:06PM
Autokrafters are the better ones...oem fit
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 09-May-2018 at 10:31AM
Just to follow-up with this thread, I did dig my window sweeps out of the garage and they are also Repops brand.  Like Compton said, they are molded to the metal and don't look like they can be removed without damaging them.  Based on the fit and difference from OEM, I would not recommend the Repop kit unless you have no other option.  I am not sure if there is a better repro brand option.
