  New Posts New Posts RSS Feed - 4-Speed Flywheel Starter trouble
fordsplus View Drop Down
Brand New Member
Brand New Member
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordsplus Quote  Post ReplyReply Direct Link To This Post Topic: 4-Speed Flywheel Starter trouble
    Posted: 16-June-2016 at 9:33AM
I have a 1971 Torino with a 1971 429 engine I also have a toploader an 11" clutch with a 164 tooth flywheel.  Can't seem to find the right match up since the starter doesn't make contact with the flywheel.  What am I doing wrong can someone tell me the correct set-up for my issue???  Thanks!
torinojon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote torinojon Quote  Post ReplyReply Direct Link To This Post Posted: 06-July-2016 at 3:50PM
you just put this together.wright.if this is all new i think you got the wrong fly wheel.it needs to be i think 176 tooth flywheel... .
Post Options Post Options   Thanks (0) Thanks(0)   Quote torinojon Quote  Post ReplyReply Direct Link To This Post Posted: 06-July-2016 at 3:58PM
are you running the bb 429 cj bell housing or the 351m/400 bell housing.theres diff flywheel per bell housing. 176 is 429 cj bell big input tranny housing.the 351m/400 is truck bell housing small input tranny.i dont no the tooth count for that flywheel.i think i got one...
Edited by torinojon - 06-July-2016 at 4:01PM
Billy C View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Billy C Quote  Post ReplyReply Direct Link To This Post Posted: 08-July-2016 at 11:26AM
I have a 176 tooth flywheel in the T10 400/351m bell housing and use a starter for a 1992 F series 460 truck with M/T. I use two washer (.125) to space the starter back so the teeth disengage all the way.
