p/s pump restore |
ramair351
Senior Member Joined: 08-May-2006 Location: west michigan Status: Offline Points: 1561 |
Posted: 07-June-2008 at 2:28PM |
hi guys, i am restoring/rebuilding/resealing a 73 power steering pump. I have found a kit to do it. but anyone know the proper color? all rebuilds I have seen are black, and most originals are greasy brown/black. but actually, underneath all that grime. they seem to be painted a dark metallic blue. This color is on the reservoir and the cast pump. I have 2 of them. from different cars, and they are both this way. I believe they are made by saginaw. anyone ever seen this blue?
-Pete
1972 montego GT 1970 Torino cobra SCJ 1970 mustang mach 1 1965 Falcon futura |
mcford
National Parts Depot has the correct color in a spray can.
starsky76
Senior Member Joined: 28-March-2008 Location: vegas Status: Offline Points: 1385 |
Yes that is the correct color,dark metallic blue.My friend shane had his 2500 mile all original 76 starsky&hutch limited at carlisle and the p/s pump was that metallic blue color.I got lots of pics of it.It is probably the same blue from at least 1972-up.Where did you get the reseal kit from?I could probably use one to.
ramair351
this is what i came up with, its actually darker than the picture shows, the flash reflected off the metallic paint. i was tired of the pump always having this greasy residue all over it. as well as every 72-73 torino i have had. i got the reseal kit from parts plus, Edelmann #8500
-Pete
starsky76
Looks good!
GranTorinoSport
How difficult is it to rebuild a P/S pump? Are there any special tools needed (like an arbor or anything)?
Webmaster |
ramair351
i didnt actually rebuild it, it worked perfectly. and i couldnt find a rebuild kit anyway, just a reseal kit. the reseal kit did come with a new shaft bushing that had to be pressed in, thats the only special tool needed.
-Pete
GranTorinoSport
I assume the differences between a reseal kit and a rebuild kit (if they made one) would be bearings? As I would assume that a reseal kit would have all of the seals needed?
I mention that because I have never had a pump fail due to bearing wear out, rather they just end up leaking so darn badly that you are forced to replace them.
And probably 20% of the power steering pumps I have installed in the last 15 years also were leaky, at least a bit (some worse than others).
Webmaster |
ramair351
there were no bearings inside really, just that sleeve/bushing thats kind of a babbit bearing material. about 8 tiny rotors and springs that rotate in a concentric, that will fly all over your workbench if you dont know to expect them. you cant really beat the full frame torino p/s setup, one finger ease, and almost never a failure. except for leaks.
-Pete
ramair351
I finally got around to installing the pump, I must have put all the pistons and springs back in right! it took alot more fluid than i planned on, I was scrounging in the garage pretty hard. Still it groaned and growled alot for about 10 minutes before it calmed down. No leaks so far....
-Pete
