  New Posts New Posts RSS Feed - 69 torino cj engine mounts
dutchtorino View Drop Down
Brand New Member
Brand New Member
Post Options Post Options   Thanks (0) Thanks(0)   Quote dutchtorino Quote  Post ReplyReply Direct Link To This Post Topic: 69 torino cj engine mounts
    Posted: 11-February-2017 at 1:34AM
hello all!!
i'm new on this forum, i'm currently working on a 69 torino q code car.
Sadly the 428 is not in the car anymore, i now have a 390 to play with untill i find a 428.
Only problem is: the engine mounts are missing :(
I live in the netherlands so its hard to find them here, and now i want to make them myself, so could anyone be so friendly to post pics with measurements?
Or give me the distance between the oil pan and the frame of the car, and the distance from the firewall to the engine? so i now i have the right position of the engine
Pics are coming soon :)
jedclampit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jedclampit Quote  Post ReplyReply Direct Link To This Post Posted: 19-April-2017 at 5:27PM
https://www.rockauto.com/
Look them up, VERY cheap, pics available too!
Nuggets View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 19-April-2017 at 11:04PM
If you want to make your own, bolt the trans in first then bolt engine to trans and lower the engine......should have about 1" clearance between pan and crossmember
In fact there might even be a set on ebay uk from memory
Barnaby
This page was generated in 0.107 seconds.
