  New Posts New Posts RSS Feed - Blower motor resistor
72GTS351CJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Topic: Blower motor resistor
    Posted: 16-November-2017 at 12:51PM
What's the deal here? Looks like plastic rivets. Any help would be appreciated
Edited by 72GTS351CJ - 27-November-2017 at 2:32AM
72GTS Clint Eastwood Special
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 16-November-2017 at 4:11PM
yes that's what they are, just gently work them out Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 17-November-2017 at 12:46AM
Thanks C.J. I will pull the glove box and try and massage it out. I have a melted plug on my heater switch so I figured I'd start here
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 27-November-2017 at 2:38AM
It physically looks good. What would be the proper way to test it. I have a melted plug at the heater switch. I figured it was this or the blower motor. I don't mind changing both but I can't seem to find the exact resistor. Thanks for any help
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 27-November-2017 at 7:52AM
I can check a factory service manual to see if there is anything there on how to check the resistor.  But I probably won't be able to get back to you until tomorrow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 27-November-2017 at 12:56PM
Don't knock yourself out. I'm trying to find a replacement anyway. I see a few on eBay that look similar but not exact. I might take a shot with the best looking candidate
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 27-November-2017 at 2:15PM
ohm meter?
plug it back in & check volts in each range?
FWIW if the plug melted the resistor is probably still working (getting hot)
melt down might be caused by a poor connection in the plug
if worse comes to worse pretty much any resistor block you can find with the pigtail can be spliced in ...
think Mustang, F series
Edited by Rockatansky - 27-November-2017 at 2:19PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 27-November-2017 at 3:15PM
Agree with Rock, put a meter on it and measure resistance. Probably a bad connection, nothing discolored and no evidence of a melt-down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 28-November-2017 at 6:52AM
Thanks. I see your point. I found a n.o.s. one I'll throw it in anyway and move on to the melted plug
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 28-November-2017 at 2:29PM
Rick, is your car is an A/C car?
If so you can check the draw at the blower motor by running an ammeter in series. According to the OEM specs, an A/C car should have the following draw at the motor (at 12.2 volts)
low:  5amps
med-low:  11 amps
med-high:  17 amps
high:  23 amps
You can also check the blower switch for shorts to ground by turning it off, and using a test light to probe between terminals for each setting.  If it lights up, you have a short.
Start with this and see what you find.  Good luck.
Edited by 72FordGTS - 28-November-2017 at 2:30PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 28-November-2017 at 2:41PM
Wow!!! Great information. Thanks for going out of your way for me. I'll be at it this weekend. And yes a/c car.
