  New Posts New Posts RSS Feed - Rack and pinion steering
Postma98 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Postma98 Quote  Post ReplyReply Direct Link To This Post Topic: Rack and pinion steering
    Posted: 13-December-2017 at 6:14AM
Does anyone know if there’s an aftermarket rack and pinion steer setup for a 72’ Mercury montego?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 13-December-2017 at 8:49AM
I've never heard of one
not that i know everything but i think if there was one out there i'd've heard about it
obvious choice for a retrofit would be the rack from a 2003 + Crown Vic / G' Marquis
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 14-December-2017 at 1:53PM
I have never heard of one either.  I'd suggest if you want rack and pinion, you're going to have to fab it up from scratch.
Alternatively, you can always install a Saginaw steering box with 12.7:1 ratio and firm feel to get ride of the stock overboosted slow steering.  That'd be as best as you can get with recirculating ball steering.
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 28-December-2017 at 1:02AM
I have the Lares 841 fast ratio box, later Ford high volume PS pump, '78 Cougar hose set, aftermarket cooler and it made a huge difference in mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 28-December-2017 at 8:08AM
X2 here, once I installed my "homemade" quick ratio steering box. Much more enjoyable to drive, almost like it's on rails.............................almost.
If those looking at a steering change would install a quick ratio box first, they may lose interest in the installation of RnP.
