  New Posts New Posts RSS Feed - Body interchange parts ?
RustyTrustyF150 View Drop Down
Brand New Member
Brand New Member
Post Options Post Options   Thanks (0) Thanks(0)   Quote RustyTrustyF150 Quote  Post ReplyReply Direct Link To This Post Topic: Body interchange parts ?
    Posted: 04-February-2018 at 7:23AM
  Hello , I can say newbie here ,      Always had some questions maybe some one can answer .    Have a 1974 Gran Torino .    Sure like the 1972 and 73 sport hood with the hood scoop on them and wonder if a 72 or 73 hood would fit on my 74 if I should ever find one .
   Second is would a front clip off a 1975 cougar fit a 74 gran torino ?   The 74 Gran Torino has that big plastic grill where the Cougar's I think is metal but not sure .     Confused
n2fordwagons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 04-February-2018 at 8:56AM
72 is the only year that the scoop was on the gts hood. It is a 1 year only hood, will not bolt onto your 74. Some folks have taken the scoop section from a 72 hood and grafted to a 74-76 hood. That would be your only option.
Jeff
71 Torino Brougham
72 Gran Torino Squire
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 04-February-2018 at 6:47PM
^^^ yes what jeff said!! the cougar profile body lines are different! won't line up with the torino's body lines at the door!
kbrace223 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kbrace223 Quote  Post ReplyReply Direct Link To This Post Posted: 07-February-2018 at 11:50AM
I am a newbie as well can I put the front clip from a 72 gts on a 73 ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 07-February-2018 at 2:11PM
the frame horns where the 1972 bumper mounts are 1 year only, 1972
the 73 uses 5 mph impact absorbers where the 72 is solid mounted, different frame
it's been done more than a couple times, get a set of 72 frame horns and weld them on then the complete 72 doghouse fits the 73 body shell
next problem is the availability of good 72 sheet metal, being 1 year only it's hard to find
the 72 grill trim alone is crazy money
would you be good with a 73 bumper tuck and hood graft?
This page was generated in 0.111 seconds.
