1970 Torino GT 429 Carb Question |
opschief3537
New Member Joined: 22-February-2018 Location: NC Status: Offline Points: 17 |
Posted: 02-March-2018 at 5:42AM |
Greetings All,
I'm restoring a 1970 Torino GT 429 w/C-6 and A/C. She is an N code example and I need some expertise identifying the correct carb. From what I have determined (from a few Ford websites) she came from the factory with an Autolite 4300 series carb. I'm not exactly sure what code carb though, because I've come across two different codes; D0OF-E or a D0AF-AM. If anyone can provide some clarity, that would be excellent! Thanks and have a great weekend all! Rod
Freedom is not free. Make it worth it!
dave302
The D0Of-E is a rochester quadra jet spread bore carburetor. It came installed on most 1970 429 CJ engines. It is not an autolite 4300 carburetor.
Edited by dave302 - 02-March-2018 at 7:35AM |
dave302
In the picture below, the D0Of-E carb has a spread bore venturi pattern. Small primary venturies and larger secondary venturies.
Edited by dave302 - 02-March-2018 at 7:10AM |
dave302
The D0AF-AM is a ford autolite-motorcraft 4300a carburetor. It came installed on some 429 n code engines in 1970. It has a square bore venturi pattern, which means that it has similar sized primary and secondary sizes.
Edited by dave302 - 02-March-2018 at 7:36AM |
dave302
There is a picture below of a D0Af-AM square bore carb gasket.
Edited by dave302 - 02-March-2018 at 7:13AM |
dave302
The autolite-motorcraft 4300-A carburetors came with two different primary venturi sizes. A size 1.01" venture was installed on some 1969 351W engines, and some 1970 and 1971 351C 4v engines. The 1.25" venture size carburetors were installed on the 1970 429 n code engines.
Edited by dave302 - 02-March-2018 at 9:47AM |
dave302
There is also the motorcraft 4300D carburetors. They were originally installed on the 1972 through 1974 351C Q code CJ engines. They have a spreadbore throttle bore design.
dave302
There is a picture below of the motorcraft 4300D spreadbore design. It is different than the Rochester quadra jet spread bore design.
dave302
A seller might be advertising that they have a motorcraft 4300 carburetor for sale, but it might be a motorcraft 4300D carburetor. It can be difficult to find a way to adapt the 4300D carburetor onto a square bore intake manifold. You probably have a square bore throttle bore pattern on your N code intake manifold. There is a picture below of a square bore intake manifold throttle bore pattern.
Edited by dave302 - 02-March-2018 at 10:32AM |
opschief3537
Thanks for the education Dave!
So aside from the D0OF-E, Rochester quadra jet and the Autolite-Motorcraft 4300-A, D0AF-AM, was there any other carburetors used on the 1970 Torino GT, N code 429, Automatic with A/C that I can continue to search for? |
Some early 429s were available with a 2bbl...
dave302
The D0OF-E Rochester quadra jet carbs were used on the 1970 C Code 429 cobra jet engines and they were probably also used on the 1970 J Code 429 cobra jet torinos with the ram air option. I have never heard of the ford factory installing them on the 1970 N code 429 engines. There might be an adapter plate that you can use to install the D0OF-E onto your engine. But the Autolite-Motorcraft 4300-A, D0AF-AM would be more of a direct fit onto your intake manifold if you have the 4 barrel square bore pattern on your intake.
Edited by dave302 - 02-March-2018 at 2:01PM |
opschiefe3537 what intake manifold do you have, if i missed it ?
the Ford Rochester Quadrajet is very rare 1 year only IIRC, the 4300-D is a spreadbore but came later model years, yes there were 2bbls even if Chilton/others don't list the option if you have a Holley 4150 pattern square bore intake, measure the throttle bores because some Holleys have larger diameter throttle blades and they won't open all the way http://www.championcarburetor.com/7074-motorcraft-4300a-carburetor-600-cfm-4v-remanufactured-p-10694.html probably pretty much the same carb you'd get from Rockauto |
opschief3537
Thanks for all the help guys!
The build sheet and Marti report show that she was an N code ordered with a 429 4V. She was bucked May 7, 1970 and actually built May 12, 1970. I'm gonna search for an original 4300-A, D0AF-AM carb. Question, as I search for a date code correct carb for my Torino, would a Feb to Mar dated carb be correct? I thought I read that engine parts should be dated 60-90 days before the actual build date of the car? Have a great weekend. Rod |
I checked the Ford Master Parts catalog. It lists a bunch of carbs for the 429 Torino's (N-code).
C6 Trans and Imco - D0AF-K, AG, AM, AN I know my car was build the end of march, most of my engine parts are dated sometime in February. |
opschief3537
Thanks Vince!
Are all of those carb codes correct for an N code, C-6 with A/C? Rod
According to the parts catalog, those are all correct. There is only two listings in the catalog for the 429 N-code engine. One is for the automatic (as I listed) one is of the 4-speed. It does not specify with or without A/C in either listing. The CJ cars used different carbs depending if A/C or not.
rear gear ratio may play into the A/C or not thing, and thus the carb thing
a car spec'd with a performance rear gear may've got a larger venturi carb Edited by Rockatansky - 06-March-2018 at 9:54AM |
date code's a little early but find another one!
https://www.ebay.com/itm/REMAN-429-Cobra-Torino-Autolite-Carburator-N-Code-Thunderjet-Auto-GT-D0AF-AG/173197784506?hash=item28536475ba:g:DH0AAOSw4CFYyfTb&vxp=mtr |
