  New Posts New Posts RSS Feed - 73 Torino 4-door Losing power/stalling at idle
Papeandtaper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Papeandtaper Quote  Post ReplyReply Direct Link To This Post Topic: 73 Torino 4-door Losing power/stalling at idle
    Posted: 06-April-2018 at 7:17AM
Hi All, First post here. I'm glad to have found you all.
I just purchased a 73 Gran Torino 4-door with the original 302 in it. I'm having some issues, which I'll outline here:
- Idles fine on start, but once engine warms up it will die if I take my foot off the accelerator
- Again, on start it is fine, but once it is warm I lose power on acceleration. It feels like the engine is cutting out momentarily and then coming back in
- Even with my foot on the gas, sometimes it will die when I switch from park to drive
My first suspicion was a vacuum leak, which may be the case as many hoses are quite old. I'll be spending the weekend tinkering with the idle to see if that's the problem. I also suspect it could be a needle valve issue.
If anyone has any experience with such symptoms, any help would be very much appreciated!
Many Thanks,
Mat
7T9_Tbird View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7T9_Tbird Quote  Post ReplyReply Direct Link To This Post Posted: 06-April-2018 at 8:36AM
Does your motor still have the thermostatic vacuum switch? if so, check it for cracks.  i had one in a 71 Mustang(my first car). Was just as you described, and I went round and round with it until I did the wd-40 trick and found the barb for the rubber hose was mostly broken.
John
79 Thunderbird Heritage
79 Thunderbird Town Landau
02 Ram 1500 Sport Quad Cab
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 06-April-2018 at 1:50PM
Another possibility is points/condenser. A weak condenser will act like/feel like a lack of fuel/vacuum type issue and it frequently gets worse with heat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 06-April-2018 at 2:28PM
What's the idle speed set at when it's warm?  What are you running for ignition?  What carb, I am assuming stock?  Have you checked the if the carb accelerator pump is shooting fuel?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Papeandtaper Quote  Post ReplyReply Direct Link To This Post Posted: 07-April-2018 at 11:03AM
You seem to have found the issue! I had a couple barbs that were cracked. Installed all new hoses today and it’s running great. Thanks everyone!
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 07-April-2018 at 12:04PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7T9_Tbird Quote  Post ReplyReply Direct Link To This Post Posted: 07-April-2018 at 2:50PM
Thumbs UpBig smile
John
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 07-April-2018 at 4:54PM
Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote changinlatitudes Quote  Post ReplyReply Direct Link To This Post Posted: 08-April-2018 at 2:48AM
Beer
Matt
1969 Mercury Marauder 390
1972 Montego MX
2003 Mercury Marauder 300A
1994 F-150 5.8
2016 Ford Fusion Titanium
