Chassis Stiffening - Lincoln cris-cross struts? |
fordismyboss
Posted: 06-May-2018 at 9:29AM |
Love the way my '72 torino handles with everything new! But I don't like the shimmy/vibration/flex when I go over bumps!
Has anyone installed these Lincoln Mark IV/V cris-cross chassis struts? Will they fit a torino? I know I'll have to weld on the front brackets. If anyone has done this, does it help? Some 1973 Montegos have similar struts on the front, not sure about '73 torinos. Any other chassis stiffening ideas? Thanks! |
madmaxtorino
they will bolt on if you add the brackets, or you could just make some custom bars.
Allan
fordismyboss
Has anyone bolted some of these Lincoln struts on? If so, any feed back?
I just found a set, will install and report back! |
Senior Member Joined: 19-December-2011 Location: Summerfield, Fl Status: Online Points: 2271 |
They "should" help stiffen the chassis a bit, had a set on a '75 Cougar XR7 I had years ago. One thing though, made changing oil a bit of a hassle(note drain plug location to brace).
They might help a bit. If anything I bet these would quell vibrations more than stiffen the frame. Lincoln was more concerned about smooth quiet rides than a stiff chassis.
fordismyboss
Well, the results are in. And I have to say that these struts do a
very good job of quelling shimmy and vibration, and have also stopped
many small rattles and squeaks. The chassis does not feel stiffer just a quieter smoother ride. Just what Lincoln (and me
too) were looking for.......this pic was taken just before the brackets were welded on. |
Thanks for the feedback. Nice to hear that they do work. Do they block the oil drain plug? Do you think they'd work with long tube headers too?
72GTS351CJ
I like it!!!
72GTS Clint Eastwood Special
fordismyboss
No issue with the drain plug. Oil will fall onto the strut, but access to the plug is fine. My oil pan is 1970 429 Cobra Jet, which should have the same drain plug location as the 1972-78 Lincoln Mark IV-V 460. They MAY work with headers(?) I'll post some better pictures which might help......
Nice work, very clean! Looking at the pic I believe headers, at least the Hooker 6126's "should" clear the brace now removing the starter looks like it may be an issue, but I could be mistaken.
isn't that kinda sad that some jungle-gym bars screwed to the bottom of the frame can make a noticeable difference ...
They're not as strong as jungle gym bars, think conduit with the ends flattened. Mostly they break up the harmonics on vibrations.
GMT 800 trucks (99-06 Silverado/Sierra, etc.) added a similar arrangement to help with what they call "Frame Beaming" which is a resonating vibration at certain speeds. Like the Marks, the truck braces rot out up here in the salt/snow. |
decent conduit anyway, not 1/2" seamed EMT i have a set hidden under a shelf rack somewhere, i wish i would've cut the front mounts off the car but that was before i knew how easy that was to do
With the front clip off my car and it being supported by jack stands at the torque boxes, I can actually flex the frame a bit. Although I am sure the front end sheet metal helps to stiffen things up, I am not surprised these braces help too. These frames are not overly stiff but that's the way Ford designed them.
