OEM AC R12 system restore |
TV 2M8O
Posted: 09-May-2018 at 12:02PM |
Guys,
Getting very near to sending my car off to the body shop and while she's gone, I want to get all the original OEM AC components ready so prior to final sheetmetal installation, I can go in and install all the AC underhood components so things will be in order for system R12 charging once it's out of paint. My original AC system was was fully charged (R12) prior to being pulled and shipped to me and I recently purchased a second condensor, accumulator hose assembly, compressor hose assembly and liquid tube from a charged R12 system that was being upgraded and converted to R134. My question is which parts can be flushed, which parts can be reused and which parts need to be replaced.... Condenser & Evaporator: pressure check and FLUSH Suction Throttling Valve: pressure check and FLUSH Liquid Line: check for abrasions and FLUSH Compressor to Receiver/Drier (@ condenser) Hose: check for abrasions and FLUSH Expansion Valve: REPLACE Receiver/Drier: REPLACE Accumulator: REBUILD AND REPLACE BOTH HOSES Compressor: REBUILD & REPLACE CLUTCH NEW HBNR O-rings So am I on track or out in left field? As always my thanks!!
All looks good! Joe, when I re-did my system I removed and flushed the evaporator and condenser using lacquer thinner and an old 12v electric fuel pump. The fuel pump circulated the lacquer thinner for about 20 minutes on each part, then turned pump around and flushed parts backwards. Then flushed with a recommended flush fluid to rid the internals of the LT(the lacquer thinner quickly gets rid of years of accumulated "nastiness").This really cleaned the internals to a "squeaky" clean. Make sure you have STV tested, new expansion valves)from what I have been told) are based on 134a performance but that is a good thing since it will flow a bit more Freon for the R12 system. Make sure you use #525 mineral oil on all O-rings prior to assembly, having/using new hoses(suction and pressure) is best and saves headaches. Good luck on the A/C work, NOTHING like using R12 in an R12 designed system.
TV 2M8O
WOO HOO.... we were scrounging around in the dealership equipment room and unearthed the old R12 charging station... a Robinair 10854. Got REALLY excited when I saw an R12 canister setting on the cart.... dang, EMPTY! Now to locate a users manual.
Thinking now I may try to "assemble" the system on the floor and pull a vacuum on it to check for leaks and then pressurize it to check things on the positive side to verify things before installing them on the car. Would that be a valid pre-assembly test?
