C-6 Transmission cooler lines path |
grandpops4
Member Joined: 24-December-2015 Location: Macomb MIp Status: Offline Points: 66 |
Posted: 14-October-2018 at 7:08AM |
Hi all, can someone tell or show me in pictures how the transmission cooler lines hook up on a 1973 Gran Torino 429 with a C-6 transmission. The radiator connections are on the drivers side and the transmission connections are on the passenger side. Thanks and God Bless. Grandpops4
gm
Senior Member Joined: 30-July-2010 Location: On The Road Status: Offline Points: 6070 |
they cross from side to side in front of the oil pan part number in ad is correct for 72+, listing text states 70-71 for some reason
Port routing goes like this: C6-front "output" port is routed to upper radiator trans cooler fitting. The trans cooler's lower port goes to rear "input" port of C6. Hope this helps.
grandpops4
Thanks for you responce but what I need is where the lines go. Do they go aling side the engine or where do they go. If I can get a diagram that would be great.
gm
they go along the engine near the oil pan on the passenger side and had a mounting strap to the crossmember near the motormount then cross over in front of the pan near the harmonic balancer then go to the drivers side radiator tank, if that helps?
grandpops4
Yes thanks
gm
grandpops4
Do the lines go below the motor mount and above the suspension or above the motor mount. Thanks
gm
if i'm understanding your question... they basically lay on the top of the cross member between the inside of the motor mount and the oil pan, straight below the pan bolts
