  New Posts New Posts RSS Feed - Bump Stops
Bump Stops
tommywommy99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tommywommy99 Quote  Post ReplyReply Direct Link To This Post Topic: Bump Stops
    Posted: 26-October-2018 at 3:57PM
When I started restoring my car, I removed the bump stops above the rear axle. How in the world do you install new ones? Any ideas?
1971 Ford Torino 500, 302 2 BBL
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 27-October-2018 at 7:48PM
not sure on the 70/71's, i'm assuming they are similar to the 72-76 torinos? if they go into a slot usually they are pulled in with pliers, if you can't access the back side then you would need to gently work them in with a blunt screwdriver, wd40 or dish soap will help them to slide in Wink
Post Options Post Options   Thanks (1) Thanks(1)   Quote tommywommy99 Quote  Post ReplyReply Direct Link To This Post Posted: 16-February-2019 at 3:00PM
In case anyone sees this, I figured it out quite easily. Just head the bump stops up with a heat gun and they pop right in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 16-February-2019 at 4:41PM
If you're talking about the '72+, they bolt onto the frame with two bolts. I have an available pair, I believe. I'll look tomorrow.
Dave F
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 17-February-2019 at 3:21AM
Thanks for posting a follow-up.  This is really helpful for people who have the same problem and search the forums later.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 17-February-2019 at 5:21AM
I'm assuming that you mean the part attached to the frame above the axle. I always knew them as the "snubber", and there's three -- the two axle-to-frame snubbers and the pinion-to- frame snubber.
I'll be out there to dig them out in a little bit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 17-February-2019 at 8:51AM
Yup, I have the pair of axle snubbers. I also have a pair from a '72 Mark IV. The bolt holes are the same spacing.... the snubbers are just a bit narrower, and about 3/4" less tall.
Dave F
Post Options Post Options   Thanks (0) Thanks(0)   Quote handsofstone Quote  Post ReplyReply Direct Link To This Post Posted: 17-February-2019 at 9:22AM
When I was in school, I worked at Stop&Shop which was across the railroad tracks near my house. Used to find bump stops every day left by people not slowing down on the crossing. 😄
Post Options Post Options   Thanks (0) Thanks(0)   Quote tommywommy99 Quote  Post ReplyReply Direct Link To This Post Posted: 17-February-2019 at 9:24AM
Yep, the snubbers. On the 71, they did not bolt on, they just slid in. Looked on the internet for hours before realizing that rubber shrinks when heated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 17-February-2019 at 9:36AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 17-February-2019 at 9:38AM
So, you're looking for '71 then? I didn't see that in your first post
1coolbanana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1coolbanana Quote  Post ReplyReply Direct Link To This Post Posted: 20-February-2024 at 7:07PM
Old post I know but I thought Id ask before creating a new one :-)
Id like to extend the snubbers on my 70 GT at least an inch to give myself more clearance with the 9" diff.
What would you all suggest?
I can drill tap and bolt a plate on but are there any simpler solutions like bigger snubbers that fit the same slot?
Cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote hogfiddles Quote  Post ReplyReply Direct Link To This Post Posted: 21-February-2024 at 1:13AM
If you extend them, you give yourself LESS clearance.
You want to SHORTEN them to give more clearance.
Cut off rubber to increase available travel space.
I don’t know why you’d want to do that, though.... you’re gonna risk jamming and damaging things at one or both ends of the driveshaft.
Maybe you’re  talking about a different part??
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1coolbanana Quote  Post ReplyReply Direct Link To This Post Posted: 21-February-2024 at 8:05AM
Yes, I want less clearance so the axle does not travel up as far to give the 9" diff more clearance between it and the floor.
So I need to lengthen the axle snubbers so it cant travel up as far.
