  New Posts New Posts RSS Feed - 1970 Ford Torino Disc brakes question
Dbarker View Drop Down
Brand New Member
Brand New Member
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dbarker Quote  Post ReplyReply Direct Link To This Post Topic: 1970 Ford Torino Disc brakes question
    Posted: 13-January-2019 at 9:28AM
I need some information. I am thinking about putting rear disc brakes on my 1970 Ford Gran Torino. I would like to hear from someone that has already tackled this task and get some feedback and information. Any help would be appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 13-January-2019 at 9:48AM
not sure on the 70? but good possibility that mustangs would interchange?, if so a kit should be available... you will need a disc/disc proportioning valve for the correct brake bias front to rear
 someone else may know more...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 13-January-2019 at 11:14AM
no Gran Torino until 1972 Unhappy
https://www.fordmuscleforums.com/torino-pages/600834-disc-brake-set-up-1970-torino.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 13-January-2019 at 1:11PM
 ^^^ that only mentioned about swapping to discs for the front, he's asking about the rear
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 13-January-2019 at 1:39PM
Stainless Steel Brakes makes a kit.  I know the Torino parts places used to sell it too.
Here it is here:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 14-January-2019 at 6:30AM
did say rear huh?
my 1st look would be a complete 8.8 31 spline Ranger axle swap, good upgrade.
if not the whole axle then just the brakes?
what's the Mark IV / Versailles swap, would those work?
Edited by Rockatansky - 14-January-2019 at 6:38AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 14-January-2019 at 3:07PM
1970 has a better-than-50/50 chance of being an 8" rear end.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 15-January-2019 at 8:29AM
and small bearings 8" or 9"
torinojon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote torinojon Quote  Post ReplyReply Direct Link To This Post Posted: 15-January-2019 at 2:08PM
if the car is stock.ford did 8" in the 302 cars.if it has a 351 or bigger it got the 9".this is the way ford did it from 1969 to late 70s that i know of.pre 1969 is different rules.you can use a 28 spline 8" axle in the place of a 28 spline 9"axle ....
