Cowl Openings 72 Montego GT |
texanrebel
Senior Member Joined: 13-June-2018 Location: Houston, Texas Status: Offline Points: 208 |
Posted: 14-April-2019 at 11:27AM |
I recently discovered standing water in the access for my wiper arm upon removing the cowl screen. Had to have just become plugged as I never noticed before. I read in another thread a reference to a drain in these, but I can't really tell as I have yet to remove the wiper arm mechanism. No water inside the car thankfully, and I sucked out all the water with the vac. Is this a flapper type drain or is it just a hole that becomes clogged?
As a side note, anyone know of a source for replacement plugs for the small, oval holes in the cowl? Mine is missing one and I have scoured the net but have only located the circular type rubber plugs. Thanks as always for comments / suggestions
1972 Montego GT
1977 Mercury Monarch 1988 Ford Thunderbird Turbo Coupe |
Regul8r 2
Admin Group Joined: 02-February-2016 Location: Rapid City, SD Status: Offline Points: 447 |
There are 3 drains in the cowl.
1 at each end of the cowl behind the fender, you cant see them. the 3rd is directly below the wiper motor, straight down below the screen you removed. There is an oval shaped rubbed boot on the cowl below that pushed out area. keep digging out all the trash out of the pocket. the rubber "boot" is like a nipple with a slit in it, supposed to keep critters from getting in and let the water drain out. BUT, instead it collects dust dirt and debris that then clogs it up and rots it all out. |
Owner- www.CaNDeCustoms.com |
carl's right, it's probably plugged with leaves and crap! 67/68 mustangs have the same oval plugs for holes elsewhere but same plug
texanrebel
Thank you gentlemen...I really appreciate the assistance!
Billy
1972 Montego GT
This thread here:
http://forum.grantorinosport.org/infofront-fender-fastening-differences-1972-to-73_topic17585.html shows the cowl drain holes on the side of the cowl. Go to the fourth pic down and you will see the opening. |
texanrebel
Vince - is that it above the "F" in the word LEFT?
Thanks for reposting this...I will be roto-rooting my drains the best I can this weekend.
1972 Montego GT
I circled it in yellow in the photo. In this one the drain covers are no longer in place in this photo.
texanrebel
very good, thanks again!
1972 Montego GT
