  New Posts New Posts RSS Feed - 1974 ford gran torino electric windows
bryan oliver View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bryan oliver Quote  Post ReplyReply Direct Link To This Post Topic: 1974 ford gran torino electric windows
    Posted: 13-May-2019 at 10:38AM
hi there ,how do you get 1974 ford gran torino electric motor for the windows out ? Bryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 13-May-2019 at 2:26PM
they should fit out through 1 of the large holes in the middle of the inside of the door by the armrest area.
or are you asking how to remove the mechanism from the door metal? if it's never been removed before it will be pop riveted on!
 take an 1/8" punch to knock the center piece out then you can drill off the rivet head with a 1/4" drill bit Wink there will be 4 rivets holding it on. to reinstall it just use 4) 1/4"NC x 1/2" long bolts and poly lock nuts Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote bryan oliver Quote  Post ReplyReply Direct Link To This Post Posted: 15-May-2019 at 10:25AM
thanks !Smile
