regulator rollers |
1973gts
Senior Member Joined: 05-March-2018 Location: Grand Rapids Mi Status: Offline Points: 608 |
Posted: 26-February-2020 at 2:16AM |
I have searched the forum but have not located a definite answer on this topic. I need to replace my regulator rollers and know the ones for the front windows (Dorman 74402) but could not find if these work for the rear quarter windows. Will these work for the rear or do I need different ones and if so which ones?
Dave - 1973 GTS N code
far as i know they are the same? measure a front one and a rear one to compare
1973gts
John, the problem I have is that both my rear rollers were gone when I took the regulators out. I think I will just check and see if the new rollers fit in the guide, if so should be good.
yes that will work btw the square replacement ones are fine they don't need to be round like the factory ones were! they just slide in the track and rotate at the pivot stud actually a better design now!!!
