unpost a pic |
Camojoe
New Member Joined: 11-June-2011 Location: Byron,GA. Status: Offline Points: 25 |
Posted: 21-May-2020 at 9:34AM |
I've got the pic posting figgered out, but how do I delete pics? When I use the edit tab, then photos, the photo links still appear in the upload window. I want all the links gone, so I can start fresh. Regards, a confused Camojoe
werd tuh yuh momma and dim....
open the edit window, highlight (left click hold & sweep) what you want to disappear and hit Backspace or locate your cursor at the end of what you want to disappear and hit backspace repeatedly, or hold it down and it'll start traveling right to left like an eraser
Camojoe
Thanks for the tip, but I already tried that, it didn't give the desired results. If I go back to edit, the links are still there. I'm thinking it may take an admin to delete the pics, since they may be hosted on an off-site server. Regards, Camo
I am not sure what you are asking? Do you want the photos deleted from your post? Or from the file manager with your uploads. You can leave photos in your file manager, even if they are not posted.
