Plug wires |
Rivercrest
Member Joined: 07-December-2019 Location: Manitoba Canada Status: Offline Points: 175 |
Posted: 05-July-2020 at 3:45PM |
Hi to all, I have a conventional distributor with points. If I replace the 7mil plug wires with 8 mil / 800 ohm wires will I have created a detrimental effect on engine performance......I was thinking bigger is better or am I taxing the ignition system for no good reason??? Thanks for your input.
8mm will be just fine better insulating purposes
Rivercrest
Thanks, must appreciated.
Bob
1974 Cougar XR7 with a 72 351C |
get the lowest resistance you can find, i usually run copper core wires on most of my cars and cut and crimp to length works fine with a resister plugs! i wanted red wires on my torino so i had to get resister wires to get that color but they were low ohms and spiral wound stainless around carbon resistor cores so they work fine...
I agree with John, no issue with the 8mm. I ran 8mm with my old point ignition which was later upgraded to with Pertronix. I also cut and crimp to length. The pre-cut wires are never the correct length.
truth! ^^^ they come in 2 sizes... too long, and way too long!
