wiring help |
1973gts
Senior Member Joined: 05-March-2018 Location: Grand Rapids Mi Status: Offline Points: 615 |
Posted: 08-August-2020 at 7:55AM |
Need some help on this, I have a two wire connector under the dash with a male/female connector and a plug downline like it goes through the firewall but not sure where it goes or what it's to. The wires are red/yellow hashtag and brown/yellow hashtag. I checked the wiring diagram and the closest thing I can come up with is something with the emissions system. Any help would be greatly appreciated - thanks - dave
Dave - 1973 GTS N code
looks like the tach wiring?
1973gts
Would that connect to wiring from the distributor then?
it runs into the wiring harness but it's basically inline for the positive to the coil
i'll check a tach and see what color wires they are red i think but they may change as it goes through the harness...
1973gts
Thanks, John, like I said the closest thing color wise on the wiring diagram was emissions related, if I don't have to run it into the engine bay area I'll just secure it in the dash area.
rancheromac
Member Joined: 12-August-2013 Location: IOWA Status: Offline Points: 58 |
cruise control
