INFO: The Official Tire Size Thread |
Post Reply | Page <1 1112131415 17> |
That is a pretty tall tire. My Wrangler has 33-12.50's and that is only 1 inch taller. My '72 wagon has 275/60-17's and they really fill up the wheelwell. They are 12 inches wide, but not 32 inches tall, though.
Edited by unlovedford - 29-January-2015 at 2:44AM |
NwOh_Starsky
Senior Member Joined: 17-December-2010 Location: Na Status: Offline Points: 422 |
I like a very tall tire, but I know you sacrifice width. I used to run a 255 70 15 on the rear. I plan to again.
Nuggets
I'm using lifted springs on the rear, they'll fit
If not my other option is 285/70/17 |
Skinnys Garage
Senior Member Joined: 26-February-2010 Location: South Dakota Status: Offline Points: 277 |
Tall tires get close to the rocker, but that could be cut. The problem I ran into was the frame near the lower control arm mount in the front. The frame curves out to the rocker and limits how tall you can get away with. I suppose a lot of dish would help, but tucking the tire in would require some surgery. Here's an old snapshot of mine with 29.5/11.5 slicks squeezed on some 7.5" ET's. everything actually tucked inside the wheel well, but did leave rub marks on the frame.
Scott -'73 Gran Torino Brougham
Past Torino's -'73 Q-code GTS, '76 Original PS-122 S&H, '73 H-code GTS, '73 Ranchero '71 Cobra 351 Auto, '70 351C Brougham 2dr HT, '71 351C Ranchero |
Nuggets
Assuming your car hasn't been lifted though? I'm planning on using a 1.5" lifting block on the rear in order to get some extra height and bring the tyres down past the usual point on the body a bit
A lot of people seem to get away with using wider tyres 305/315 but no one seems to like tall tyres.....I like a tall tyre so 285/70/17 should be able to fit with some fettling, even if I need to roll the arch or something like that
255/70-16 will fit on the back of a 79 t-bird using crown vic wheels, but they hit the back corner of the wheel openings in the front wheel wells when cornering. (looked wrong too...)
Skinnys Garage
OleDutchD
Member Joined: 02-August-2003 Location: Tennessee Status: Offline Points: 151 |
295/45-18's are 28.3" tall with an 11-1/2" cross section. On a 9-1/2" rim w/ a 5" backspace, they clear the lip and frame rail (at its' tightest point, in front) with 1/2"-3/4" clearance. Still has 5" of sidewall to give the appearance some 'beef' but, at 40 psi, the sidewalls don't flex and let things rub. That's what I've been running (without incident) for the past two years. Still want to drop the rear end 1" to 1-1/2", and may consider trimming the lip a bit at that point, but there's been no drama and the tire fills the wheelwell nicely.
Edited by OleDutchD - 29-January-2015 at 12:30PM |
Just an analog guy stuck in a digital world!
Nuggets
285/70/15 fit with no issues so I don't see 285/70/17 or 65/17 being an issue! Tall tyres here I come
Edited by Nuggets - 30-January-2015 at 5:11AM |
285/70-17 is 2" bigger height-wise than 285/70-15
So it will need 1 more inch of clearance and be almost 33" tall Edited by Big Bird - 30-January-2015 at 11:37AM |
Nuggets
1 more inch of clearance vertically shouldn't be an issue though, a good set of springs should sort that
I can go 285/65/17 if needed but that throws my gearing off a bit, I've calculated my 5 speed conversion with 4.86 gears using a 32.5" tyre which is what the 285/70/17 equates to. I'd have to drop to 4.75:1 using the 65 wall tyre, not a huge issue admittedly but the price difference for tyres makes me want to get the 70 on there as they're cheaper!
My F150 with the 4 X 4 Off Road package has 265/70-17 Michelins. That is a LOT of tire. If anyone wants to see what that size looks like under a Torino, I have one of the old Michelins I removed from the truck and can stick under the '75 GTS I have on the trailer. I can jack it up until the wheels come off the ground to see what kind of clearance it would have.
Nuggets
Please!
I've settled on 285/65/17 now anyway as its only a few cm bigger than the 285/70/15s
vols35
New Member Joined: 09-February-2015 Location: tennessee Status: Offline Points: 3 |
this site helped me figure what kind of tires and wheels to buy. I ended up buying m Thompson 28x12.5x15 tires with weld 15s with 5.5 or 00 offset perfect fit
Regul8r
Give us a picture PLEASE!!! |
vols35
whats the best way to post pictures and what topic should I send them too
this is how i do it: go down to the 3rd post,sounds confusing, it's not, after you do it a few times it's fast and easy http://forum.grantorinosport.org/how-to-post-a-picture_topic3712&FID=4&PR=3.html |
RAPTOR
Senior Member Joined: 25-July-2013 Location: Florida Status: Offline Points: 267 |
I finally got the new Rims and rubber on, The size and look i want is on the money !!
275/60/15 and Front 255/60/15 |
1972 Torino Sport 4Spd Q 351c
1996 Bronco XLT 2010 SVT Raptor 2003 H2 Hummer 1977 CB 750 Cafe Racer |
same width wheels F & R ?
Nuggets
Ok I've ended up with some 285/60/17's
They're arriving on Saturday so I'll get some pictures up then :)
Nuggets
Will get them on tomorrow and post fitted pics |
ilyes
Man, that's what I have on my Jeep, decent snow traction too.
Nuggets
They'll fill the arches nicely, they're an inch bigger than my current wheels and slightly smaller than the 285/70/15s which were fitted to someone else's car!
Means they should definitely fit as I measured .9" clearance to the lip of the arch, these are a full inch bigger so .5" should give me .4" clearance......looking forward to getting them on once the sun comes up!
Nuggets
And they're on! Fit perfectly........so thats 29.1 front and 30" rear 255/65/16 front on 16" modular D wheels, 285/60/17 on 17" modular D wheels |
ilyes
Anybody running 18x9.5? I'm looking at a set of mustang wheels pretty cheap.
I need to find wheels to work with the tire size I'll be running, 285/35/18 in the rear, 265/35/18 in the front. I want to run a set of Michelin Pilot Super Sport, so I got to find rims to work with it.
what's the rear spacing on those wheels?
ilyes
They won't work, dang it. Here's the rims:
n2fordwagons
Yeah, the backspacing on newer model Mustangs is about the same as FWD. You'd need at least 1.5 - 2.0" spacers. If you could find wheels for a 94-04 Mustang, the offset would be closer. You could get by with 1.0" spacers. I think that's what Joe uses for his Bullitt wheels.
Jeff
OleDutchD
Yes. 18x9.5 (5" BS) out back, with 295/45-18's. Worked out perfectly. |
Yep, no issues with my 18's and a spacer.
