  New Posts New Posts RSS Feed - INFO: The Official Tire Size Thread
 Post Reply Post Reply Page  <1 1314151617>
n2fordwagons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2017 at 12:47AM
Here's how 17" 40 series tires look on our cars, with standard ride height.
Fronts are 275-40-17.  Rears are 315-35-17.
Jeff
71 Torino Brougham
72 Gran Torino Squire
Nuggets View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2017 at 1:11AM
I like the 315s I've got 275/60/17 on mine currently but do fancy some wider rubber. Was thinking 305 but 315 would be even better especially if I can get them in a 29" diameter or 31
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2017 at 1:18AM
Unfortunately, I haven't had much luck finding them in a taller tire.  275 seems to be about the widest tire I've been able to find in a tire tall enough for our cars.
Jeff
71 Torino Brougham
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2017 at 1:31AM
On my gold car and red wagon, I run 17 X 8 with 235/55-17 front and 18 X 10.5 with 255/55-18 on the rear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 28-June-2017 at 9:11AM
I can buy a Toyo in that size over here, its an all terrain tyre but not an issue
Barnaby
Don V. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don V. Quote  Post ReplyReply Direct Link To This Post Posted: 08-July-2017 at 12:37PM
Width means nothing without profile ratio
I assume you mean aspect ratio but would you explain why you say this please.
Power Surge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Power Surge Quote  Post ReplyReply Direct Link To This Post Posted: 08-July-2017 at 12:38PM
I think he meant the other way around.
Sal Mennella
73 GTS 351 CJ
75 Cougar XR7
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 09-July-2017 at 3:53AM
Aspect, profile, same difference.
Because someone can say they run a 245-15 up front. Great! Butyiu try a 245/55/15 vs a 245/75/15 not the same at all!
Same for me on the rear I could say I run a 275/16 which I do......but without the sidewall height it's useless. In my case it's a 60.
But that'd be the largest height you can fit in at 30" diameter
You could also run a 275/45 and have way more arch clearance. But you say you're running a 305-17 and miss the ratio someone buys some 305/55's it's not going to fit if 305/35 is the size they need. I'm just making up ratios here but you get the point
Barnaby
And odds are someone will buy a size without checking then complain it doesn't fit under the car....
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don V. Quote  Post ReplyReply Direct Link To This Post Posted: 09-July-2017 at 2:41PM
Actually not what I was thinking but you're right. kudos
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don V. Quote  Post ReplyReply Direct Link To This Post Posted: 09-July-2017 at 2:42PM
Does that happen? Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don V. Quote  Post ReplyReply Direct Link To This Post Posted: 10-July-2017 at 3:06AM
It's been years since I've considered this so maybe it's just "old school" nonsense today on my part but I don't see them as the same.
Aspect ratio was a static number based on the off the rim section height and width. It doesn't take into account rim size. With the proliferation of low profile tires anyone using the number needs to ensure apples and oranges aren't getting mixed.
Profile ratio was an entirely different animal. It's an active number based on a tires limits and used primarily by but not limited to engineers for matching a tire to a vehicle or in motorsports, conditions. It's use is necessitated by Newton's 3rd law of motion, "for every action there is an equal and opposite reaction." Can a tire handle the performance characteristics of a given vehicle or can a vehicle handle the performance characteristics of a tire. Look at the tire rotation directions through the years. Tires today may have the same inside outside profile ratios but they are not the same left to right. Don't put a right tire on the left side. The sticky tires used in F# racing would tear up a daily driver's drivetrain and there's a good reason why biased tires are almost a thing of the past. Consider a tire used by an airline where the drivetrain is separate from the tires. These tires are designed to get taller and thinner as they approach their "at speed" limit. The approach to traction between an auto and airline is very different. A tire has more then one profile ratio because it's an "in use" number. In my day anyway.
In my day the equivalent and effective ratios were what mattered. Ensuring your tires matched the rear end gearing. Those cool, big tires often came at the expense of performance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nuggets Quote  Post ReplyReply Direct Link To This Post Posted: 11-July-2017 at 12:38AM
Whatbyoure listing as profile such as speed rating and load I'd class as specification or characteristics such as a V rating or DOT legality etc
Edited by Nuggets - 11-July-2017 at 12:39AM
Barnaby
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don V. Quote  Post ReplyReply Direct Link To This Post Posted: 11-July-2017 at 7:29AM
Barnaby,
You're absolutely right. For road vehicles all the ratings come from or are adopted from the SAE. For the daily drivers it's not much of an issue anymore because of the research that has been done and the ratings. Sometimes the envelope gets pushed though. I can't say where I heard or read this but for the newest Veyron there is only one legal tire for the car at it's rated top speed. Even then the life of the tire at speed is rated in either minutes or miles at a cost of $30,000 for a set. I just looked that cost up. You can bet tire companies are working on tires set for a new rating to accommodate the car.
The ratings exist for motorsports also. I'm not sure how familiar Brit's are with tractor pulling but when pulling started using engines like the Allison Merlin there were problems with the split rims on tractors and tires. That was solved by new ratings. Jim Thorton who in the 60's invented the drag racing torque cancelling chassis, is credited as the inventor of funny cars, was the head of Chrysler's race vehicle design and the primary driver of Chrysler's drag racing team talked a lot about how tire profile didn't keep up with the sport. Nitro burners were around long before they were legal on the strip because of tires. Even today the tires require being screwed to the rim.
The ratings per tire are based on profile ratios which is about the tire in use and not a static, off the rim ratio of section height and width. And it is section height, not tire radius.
"It's an adjustable wrench, Crescent is a brand." I heard this all the time growing up. I'm aware of how words and meanings change because of common use. I'm not at all being critical of you. Some things do irritate me but this isn't one of them. I'm only explaining what the meanings are for me.
Edited by Don V. - 11-July-2017 at 7:31AM
yellowsportwagon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yellowsportwagon Quote  Post ReplyReply Direct Link To This Post Posted: 12-July-2017 at 7:33AM
I'm running 245/45 17 4 1/2 backspace on frt and 295/45 18 with 5 inch backspace on rear nothing hits or rubs anywhere. Car is lowered 1 inch in back and about 2" in frt
Edited by yellowsportwagon - 12-July-2017 at 7:34AM
fordismyboss View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordismyboss Quote  Post ReplyReply Direct Link To This Post Posted: 14-November-2017 at 6:40AM
Probably few of us are running 14" these days but I had to post this one!
My Torino from back in the day, running 14x7 reverse appliance steel spokes with BFG radial TA 50's all around. Stock ride height. Picture taken November 1976 with my brother behind the wheel!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 14-November-2017 at 12:23PM
That's a sweet picture.  I love the look of a '72 with meaty tires on the front end, which is why I run 8" tires on the front.
72GTS351CJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 16-November-2017 at 2:27AM
Love it!!! 14's never looked so good
72GTS Clint Eastwood Special
Edrem3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Edrem3 Quote  Post ReplyReply Direct Link To This Post Posted: 25-April-2018 at 3:50AM
So I wanted to officially say thanks to everyone that posted their tire sizes in this thread. Without the help, big mistakes probably would have been inevitable. however, with the help I was able to determine the sizes I needed for front and back and ended up with
245/60/15s on 15x7 rims with a 3.75 backspace on the front
275/60/15s on 15x8 rims with a 4.50 backspace on the rear
72 MGT Qcode 4sp
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 25-April-2018 at 4:44AM
I saw your post on Facebook.  Your Montego looks great!
Jeff
71 Torino Brougham
Post Options Post Options   Thanks (0) Thanks(0)   Quote Edrem3 Quote  Post ReplyReply Direct Link To This Post Posted: 25-April-2018 at 5:32AM
Thanks! I can't wait to get the body done, but the main concern is getting her driving well. Now that I'm happy with my tire/rim choice, it's time to do some suspension work and lower it
72 MGT Qcode 4sp
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 25-April-2018 at 12:25PM
i too saw your post on FB, i voted to lower it Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Edrem3 Quote  Post ReplyReply Direct Link To This Post Posted: 25-April-2018 at 2:14PM
yeah, I'm pretty sure I'm gonna drop her an inch all around. I'll be testing it on old springs to see how I like it.
72 MGT Qcode 4sp
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 25-April-2018 at 3:43PM
 Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote changinlatitudes Quote  Post ReplyReply Direct Link To This Post Posted: 26-April-2018 at 12:51AM
Lookin' good!
Matt
1969 Mercury Marauder 390
1972 Montego MX
2003 Mercury Marauder 300A
1994 F-150 5.8
2016 Ford Fusion Titanium
7T9_Tbird View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7T9_Tbird Quote  Post ReplyReply Direct Link To This Post Posted: 26-April-2018 at 3:43AM
Looks good!Thumbs Up Personally. I like the old "street fighter" stance.
John
79 Thunderbird Heritage
79 Thunderbird Town Landau
02 Ram 1500 Sport Quad Cab
iangj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iangj Quote  Post ReplyReply Direct Link To This Post Posted: 28-April-2018 at 4:29AM
Hi Edrem3. Your Montego GT is coming along nicely. The wheel tire combo looks great.
Have you had your car information registered with the Montego GT Registry yet?
If not you can email me at ; iangj254@gmail.com  and then I can see if we have it or can add it.
We will need the VIN and info off the data decal inside the driver's door if it's still there.
Thanks
Ian Glyn-Jones
Fonthill, Ontario, Canada
Wish I had My Baby Back
Montego GT Registry
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 28-April-2018 at 7:21AM
+1, love the looks as it sits now.  Very nice looking ride.
There is a ton of information in the technical section on coil springs including stance photos.  Most of it is for '72-73 Torinos, but your car is pretty much identical underneath to a '72 GTS so it should have the same stance as a '72 GTS with the same springs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Edrem3 Quote  Post ReplyReply Direct Link To This Post Posted: 28-April-2018 at 8:25AM
Thanks!
The more I look at it the more I wanna keep it as she sits.
I've been looking at the coilspring thread and believe I got the info I need. If need be, I can always cut the new springs to match this stance
72 MGT Qcode 4sp
73 gran torino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73 gran torino Quote  Post ReplyReply Direct Link To This Post Posted: 25-May-2018 at 6:22AM
Albo74,
My name is Paul. I have a 73 Gran Torino That I bought new right out of high school.
It is in like new condition after a 2 year 100% frame up restoration, motor, Trans. and all.
I came accross the photo of your 74 Gran Torino and noticed the rear wheels, (P275/60R/15.
I am thinking of putting the same tires on the back of my Torino, but am concerned about the space they will have between the tire and the top edge of the fender well lip. And the tire and the frame just just in fron of the tire.
Can you tell me exactly how much space you have between the tire and the fender lip and also how much space between the tire and the frame in front of the rear tire. And what the back spacing is on your back wheels.
I am planning on getting the Cragar 15X8  4 1/4" back spacing  (Old School Spokes) for the rear and 15X7  4" back spacing for the front with 225/70/15 tires
How is the clearance in the front tires with turning?
Thanks for your time and help,   Paul
73torino
This page was generated in 0.219 seconds.
