INFO: The Official Tire Size Thread |
Post Reply | Page <1234 17> |
Author | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Carl, had I known...I have a pair of 15x10 Chrome Aero Racing wheels sitting in the garage, 5" offset.
Brand new in the box!
DOH!
Pondering: #99Problems |
Carl-
Here is the pick off Summit Racing's site- Link to Summit's site http://www.summitracing.com/parts/AEO-58-204550/?rtype=10 Direct link to Aero Racing's site: http://www.aeroracewheels.com/wheel_pgs/fifty_eight_series.html And for kickers, for the love of Pete someone buy my nascar 15x9.5 wheels. There are Aero Racing's type 59, true, honest to goodness super speedway wheels. Only thing is, you are going to have to run a 5x5 lincoln bolt pattern. Easy enough to change up front, but rear axle, you are going to need to get axles or redrill your bolt pattern. Oh, did I mention, you will need a 5/8" wheel stud and 1" lug nuts? |
And for your 295/50r15 pleasure:
And for the record, these wheels will turn lock to lock and not rub with 295's on them. My only issue is I saw the tire seem to get close to my wheel lips, but I have the extreme short coil spring. I did NOT fit them out back because I can't use as I didn't convert to 5x5 on my axles. I however have 11x2.5 drums, backing plates off a 77 LTD with the 5x5 bolt pattern, and a pair of usable 1972 mark5? 12" rotors. It would require getting the full size caliper bracket. |
TV 2M8O
Hey guys, Came across some pics of my old Starsky LE. I had 15 x 10 ET IV slots with LR60-15 Eagle GT's on the rear with 14 x 6 ET IV's with the OEM BF Goodrich HR78-14's on the front. Kept the air shocks about 90% filled because the wheel lip would touch just enough to cut into the sidewalls. Had I known how at the time, I would have rolled the wheel lips and all would have been fine. Not sure what the back spacing was but they were nice and deep! Here are a few pics.....
Hope this was helpful.
JOE Edited by TV 2M8O - 08-March-2010 at 3:22PM |
Regul8r
Andy,
those 15x10 black racing wheels are what offset? 5 inch?
LOVIN THE LOOK OF THOSE 295/50/15 on the front!!!
Off hand, not 100%. The rims are classed as a 15 x 9.5" rim; I have never checked the offset on the wheels to confirm.
On my GTS...depending on how much tires will end up costing, I may actually put OEM front brakes back on my car and pull the crown vic brakes because I desperately just want to really run a 295/50r15 up front. I need to debate things. No happy medium here man...LOL I thankfully have my 1976 Spindles and the 1976 9" that I may just take and redrill the axles and new rotors for a 5x5 bolt pattern with 5/8" wheel studs. I already have the correct brakes for it, and the wheels. I will however need to replace my front springs either way because the fronts are too short and I don't want the tires rubbing on the front lips. Don't know yet. I have one last option I need to look at before I give up on 295 series tires. |
Think I found my solution.
Carl, sent you a PM. Andy |
Well, bit the bullet.
Got new rollers ordered from Summit Racing. nitto 255/50R17 front and 275/50R17 out back. Crager 17x9, with help from one of the guys on Ford Muscle. My wife must really love my dumb ass.
Here is his 1972 Gran Torino...I sold him a hood like 7 years ago.
Edited by Eliteman76 - 08-March-2010 at 8:01PM |
Torinogts73c
Are those Cragar wheels or Ford Bullit wheels? They look good on that Torino! Tire sizes??
Nope, rim I picked was a 17x9, 5" backspacing {according to cragar's tech guy I emailed, the wheel is technically a 10" wide rim, lip to lip, which will have a zero offset. Will see when I get the wheels for the GTS, I will document for you guys.
I only went to this combo after deciding against a 295/50R16 BFG because I could not get a slightly narrower front tire.
Wheels are I want to say on that grey formal roof are the torque thrusts, but don't know for sure.
Regul8r
Andy,
the pics you posted of the 295's on the front...
those are with the 9.5's or 10's??
The wheels up front are the Nascar 15 x 9.5 wheels. The ones that have the 5 x 5 bolt pattern.
moose0211
Senior Member Joined: 23-September-2009 Location: Baltimore Status: Offline Points: 456 |
I love those aero NASCAR wheels. I was looking at them online and i was wondering,are the NASCAR 15x9.5s the same design as the 58 series? Would it look weird if I put the NASCARs on the back and 15x8s on the front? thanks, Lou
Edited by moose0211 - 12-March-2010 at 11:05AM |
Regul8r
MORE tire work! Here are 245/60/14 tires mounted on 14x8 rims with 2.5" backspacing
25" tire height
26" fender height
NOW here is a comparison of this tire MOUNTED next to my 265/50/15 tire NOT mounted.
First look with the 2 tires side by side and looking a them... the 245/60/14 actually looks BETTER than the 265/50/15!?
I will post all the sizes info I have for Comparisons in another post.
Regul8r
here is what I came up with...
I THINK it will look great with 295/50/15 on 15x10 rims for the rear and 245/60/14 on 14x8 rims out front.
These are VERY close in height/diameter AND sidewall, so they will look close to the same just a little thinner on the front.
That is IF I do not go with the 295/50/15 all the way around!
Apparently the 265/50/15 are an ODD size, I can only find them in a few off brand tires.
BOTH the 245/60/14 and 295/50/15 are readily available in the BF Goodrich everywhere for around $100 each.
Edited... Forgot to say I use TireRack.com and the BFG's for all the above info
Edited by cowboyupdjcarl - 14-March-2010 at 2:41PM |
Lou-
They type 59 Nascar wheels are only available in a 5x5 bolt pattern, like what the Lincoln and full size Ford/ Mercury use. Thing is, depending on how your state is on local inspections on older cars, you would be better off going to someone like Bassett. Otherwise, another source for wheels is to seriously check around at local race shops that do IMCA or modified racing. There is a race shop here in Omaha that one of my cousins use to co-own that he got out of, that they have a ton of 15" steel wheels in a 15x8 for pretty cheap new. You can also pick up cragar steel D window wheels that are DOT legal pretty reasonable, I got my set at Summit racing. http://www.bassettwheel.com/dot.html |
Regul8r
Andy,
looks like I am gonna pass on those rims at this time.
Have to decide what I am going to do on the front.
15x10 all the way around and I can use them.
If I go with the 14x8 on the front... it SERIOUSLY lessens my choice of wheels!
pretty much, but any of our cars look alot better with a wide wire to fill up the wheel well.
On the rims, the easiest is a 15x8 in front, 15x10 in back.
A 15x10 can be run on all 4 corners, but I have never personally verifed yet with the 15x10's I have being street driven.
On a street car, one thing I wanted to bring up is the fact a car with steamroler tires loks great, but wider tires have the annoying tendancy to grab ruts and wander a bit.
I drove my '84 F150 for 5 years with 295/50/15's 3/4 of the year, and I will tell you, ruts and heavy water, even with an all sean BFG radial TA would make things interedting at times.
It's been a very long time since I've driven with a 295/50r15 on the front of a Torino, not since I had my parent's 1976 Elite, have I run a 15x8 with a 295/50r15, when I was in high school in the early-mid 90's.
With that said though, a 295 will fit up front.
if the weather is decent enough, I will try to get a 295 mounted onto one of the chrome wheels and fit it on the '73 GTS front and then I will toss on the back of my '72 GTS.
Regul8r
Well I know the 15x10 rims I have will not do the trick without a little mod.
They rubbed the front AD rear of the front quarter. I think a deeper set(more backspace would let them clear without issue. I just need to make sure the offsets are the same so the front doesn't stick out further than the rear.
So I just might take the rims after all!
I got the 245/60/14's cleaned up and ready to mount just for moving and size comparison.
I have 255/60/15s on the front of my truck with 295/50/15 on the back... they look good in combo... MIGHT be a good fit all around.
moose0211
Andy-
this is kind of delayed but, Maryland couldn't care less about old cars until they cause a wreck. I love how those chrome aero wheels look and they are reasonably priced to, whats not to love!
BBPeik
Senior Member Joined: 17-July-2008 Location: San Diego Status: Offline Points: 357 |
15x8 4.5 backspace rear 275/60/15
15x7 3.5 backspace front 225/70/15 Could go a bit taller on the rear, but I was not sure and did not want to over do it. Brendan |
1973 Gran Torino Sport 357 Cleveland FMX 3.50 auburn pro posi 1969 Black Jade
Regul8r
Removed original post...
The look I want... big fat rear rubber that does not stick out ridiculously from the fender well.
Front smaller but still a GOOD size rubber and again... not sticking out... tucked in like the photo I have on here with the keystones!
I think I just found the Rims!!!
15x8 comes in 3 different backspaces, I think the 4.5 would be best? Maybe the 3.5?
thats why I am looking for a pic of the 15x8 and what tire & backspace you have.
Will fit the 245/60/15 tire which is 26.6 tall
15x10 comes in 5 different backspaces best one is 4.5 or 5.5 depends on if the 5.5 with tire rubs.
Will fit the 295/50/15 which is 26.7 tall
smaller yet same height on front
the 255/60/15 is 27.1 tall which is a little bit taller than the 295/50 rear
Pulsars are nice too...
Edited by cowboyupdjcarl - 13-April-2010 at 3:44PM |
Speaking of which, I got the 295/50/r15 mounted up today. Of course, I dropped the GTS off at the paint shop, but I could fit the setup on the '73 GTS if need be.
gpd294
I figured now that I have installed my original steel wheels and new tires I'd post a few pictures. I took it back to original, although I did fudge a little bit because I couldn't justify spending over $200 per tire (Coker Tire) for a weekend toy. I went with P215 75 14 white walls all the way around and a spare. The steel wheels were cleaned up, sanded down, and POR-15 painted. I figure if I ever do any cross country trips I'll have to upgrade to either a 15 inch or bigger wheel. Here is a pic:
EDIT: Due to original link posted is no longer good
Edited by gpd294 - 19-December-2014 at 4:20AM |
Dude, I like your wagon!
On the stock look, they fit the bill really nice.
If you happen to need a set of 15" steel OEM torino wheels, let me know.
I've been keeping a set around here in case I ever need a set of wheels for a project, but would be willing to let go to a good home. Like your wagon.
Only bummer thing is to ship them!
Regul8r
Reading back through the whole thread it appears MANY different BS have been used on the front. What it the largest measured backspace that fits on the 72?
I see a couple saying they have 4.5" of backspace.
I would like to see some good pics of a 15x8 rim with 4.5" backspace.
Pic where the rim is close to the top of the spindle by the upper ball joint and anywhere else it comes CLOSE!
Also where the tire clears the front and rear of the fender lip.
I THINK... a 15x8 with a 4.5 BS will allow the front tire to tuck up into the fender IF the car was lowered substantially without rubbing. Or at least not rub when hitting bumps and turning.
Someone help with pics?
Psquare75
I have a 17x8 with a 4.5" BS. Car is a big block on small block springs (slight lowering effct). If the nose isn't lined up PERFECTLY, it will rub in turns. I had to tweak the lower fenders a bit.
Regul8r
The 17 inch doesn't help me with my question.
The 17 will be higher and clear the spindle and the ball joints different than the 15s.
Apples and oranges
