  New Posts New Posts RSS Feed - Hood Hinge Spring questions
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Topic: Hood Hinge Spring questions
    Posted: 02-March-2011 at 3:33AM
I made the fatal mistake of greasing my hinges so I have the infamous 'hood droop'.
Anyone have a part # for new springs?
OR
Anyone know if GM springs from a Chevelle or something will work? (A bodie hinges are close in appearance to midsized Ford)
OR
Anyone have a set of Lincoln Mark V or Continental hinges? (In the past my fix was to use these springs, they have much more tension before stretching)
CheeseSteakJim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CheeseSteakJim Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2011 at 4:57AM
I didn't realize Continental springs were important, or I would've pulled them from the multiple Mark IV's and V's I saw in the junkyard a few months ago. Do you know if Panther (Vic/Grand Marq) springs will work? I'm not sure when they changed to aluminum hoods on those, but I assume it was post '87 like Town Cars. Steel-hooded Town Cars had higher pressure lifts, so I assume steel-hooded Vics must've had higher tension springs.
TopGear (TG) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TopGear (TG) Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2011 at 5:31AM
Ahh man, I did the same thing.Confused
Toby
'76 Ford Elite - Sold
Looking for a '72
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2011 at 7:23AM
Same here. I used white lithium grease, which made it harder to clean and attracted every particle of foreign debris around. Flushing them out with Purple Power seemed to help (at least on a Ford truck).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2011 at 7:42AM
I'll try that tonight. Or maybe sprinkle some dirt on the contact points. LOL
Edited by Psquare75 - 02-March-2011 at 7:42AM
NwOh_Starsky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NwOh_Starsky Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2011 at 8:02AM
I have a used set if you need them pm me for more info
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2011 at 8:03AM
Nah I'm set, I have another set in the shed, I just didn't want to remove them, paint new ones, and re-align the hood. Thanks though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TopGear (TG) Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2011 at 8:30AM
Does the hood sorta hold itself up half way?
Toby
Looking for a '72
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2011 at 8:30AM
Yeah.. It drops about 2".. Which is RIGHT where my head is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CheeseSteakJim Quote  Post ReplyReply Direct Link To This Post Posted: 02-March-2011 at 9:28AM
...and then you slam your face on the hood latch, right? I do that all the time, and it's just one of those things that indescribably pisses you off for no reason.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 06-March-2011 at 11:50AM
Solved. I dug around in the local junkyard and came across a 72 Continental.
Note the size difference (Torino OEM size is painted silver). They are fun (sarcasm) to install. Now the hood actually forces itself up quite a bit..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 06-March-2011 at 1:41PM
Good to know!!!
72 Continental springs
I wonder if truck springs would do it too?
I have a scar on my left palm from where I was caught in a 75 Ford F100 hood hinge in 1986.
I had them pushed down without the hood on it (DUMB KID).
Well I went to hop down out of the engine bay and put my hand on the hinge when all of a sudden... SPRING! and my hand was stuck in the hinge with the full force of the spring holding me prisoner! My buddy had to climb on the truck and push down on it with all his weight in order to free me from my bloody/painful hell!!! 5 stitches in the ER that day!!
Edited by cowboyupdjcarl - 06-March-2011 at 1:44PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 06-March-2011 at 2:05PM
Not sure on trucks. I have a 79 F100, I didn't think to look. I'll give an interchange of
73-78 Full Size
Mark IV
Mark V
73-76 Tbird
I'm not sure if 68-72 is the same as far as full size.
Your springs must be lubed up for these, as shutting the hood requires more force than normal.. However, Most of these hinges, once lubed, become LOOSE if anything. I'd love to find a repop source for these, or something off of a modern car at least, but everything new has gone to a 'wound-up clockspring' type hinge, a rod, or pistons.
Pistons might be worth looking into... but it might require two per side, and IMO that'd look silly.
