  New Posts New Posts RSS Feed - 351C Timing Chain Cover Replacment
mark harper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark harper Quote  Post ReplyReply Direct Link To This Post Topic: 351C Timing Chain Cover Replacment
    Posted: 11-April-2011 at 3:05PM
Does anyone know of a way to remove and replace a timing chain cover on a 351C without removing the oil pan? I need access to the timing chain gears but I do not want to have to remove the oil pan as the engine is still in the car. For any of you that have had to remove and replace a 351C oil pan while the engine is still in the car knows what a pain that it is. Let me know - Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 11-April-2011 at 6:06PM
i've always done it w/o dropping the oil pan, it can be done by trimming the corners off the pan seal rails and some of the pan seals too. a dab of RTV makes up for what gets trimmed off. getting the pan / block corners clean & free of oil is important, then schmeer a little RTV into the corners before
setting the cover.
but before that i do a couple test-fits especially if it's a 'first time' cover that i'm notching the tabs off. i make sure the cover by itself is able to slide in without the pan seal or gaskets or sealer, sometimes it takes a couple tries to get the trimming just right and you don't want goo'd up gaskets sliding all over & collecting crud while you need to cut or file a little more off the corners
i prefer to re-use an old pan seal because it's already compressed and makes it a little easier too
i have several extra covers, not sure if i have one that's already notched but i'll try to get a couple pics
Post Options Post Options   Thanks (0) Thanks(0)   Quote mark harper Quote  Post ReplyReply Direct Link To This Post Posted: 12-April-2011 at 12:37AM
Thanks Max. Pictures of this would be really helpful. Thanks for the reply.
Mark
This page was generated in 0.090 seconds.
