  New Posts New Posts RSS Feed - HELP! where can I find these??
73GTS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73GTS Quote  Post ReplyReply Direct Link To This Post Topic: HELP! where can I find these??
    Posted: 14-July-2011 at 2:55PM
I need the gasket that goes between the headlight buckets and the front fenders.
I also need the Nylon (plastic) bumpers (white) that goes behind the headlight buckets, and
the nylon inserts (black plastic nuts) that the chrome trim screws into. I will need adjusters
and springs, but I figure I can find those.
If anyone knows where to buy these things I surely would appreciate it. I have looked everywhere. Dearborn/ AK/ etc. All the Mustang shops, etc. etc.
Thanks,
Jim
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 14-July-2011 at 3:35PM
I don't remember an rubber gaskets betweent the headlight extensions and the fenders,I thought they were just bolted together. I will have to check the extension from my 73 formal parts carb but I just gave the rightside to the guy who bought the right fender. As for the headlight fastners try recearchhing automotive clips and fastners as the body shop I use to work for had a guy come around every 2 weeks and supplied us with clips,bolts and types of autobody hardware. Try search ebay also cause I see screww kits all the time so maybe they have headlight hardware but an autobody fastner supply company should have what your looking for and I am sure there are online suppliers.
Edited by 73 ProStreetTorino - 14-July-2011 at 3:41PM
Guest
Guest
Post Options Post Options   Thanks (1) Thanks(1)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 14-July-2011 at 4:02PM
Jim I looked and your right it does have a black piece of rubber in that groove but not sure if you can get it an might have to improvise. Find some thin flat rubber with about 1/ 8-3/16th thickness and cut it down and shove it in the groove.I know it is bigg money but there is a Complete NOS set on ebay with extensions,chrome bezels,headlight buckets ,headlight rings and all the screws and hardware with the adjusters and all those plastic spaceres and everything brand new but I think the price was $299 but heck I paid $172 just for the NOS Headlight bezels. Like I said check with auto body fastener companies.You could probably take a rubber vacuam hose and split it open and stick it in the groove
starskytorino View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote starskytorino Quote  Post ReplyReply Direct Link To This Post Posted: 14-July-2011 at 4:29PM
you can get the gasket from any one who sells mustang parts as they come in long strips that form to the shape of the housing
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 14-July-2011 at 4:46PM
He said he checked all the Mustang shopsn do you have any links to those strips?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73GTS Quote  Post ReplyReply Direct Link To This Post Posted: 14-July-2011 at 5:01PM
This  |  Big smile
Jim
inenidok View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote inenidok Quote  Post ReplyReply Direct Link To This Post Posted: 14-July-2011 at 5:34PM
just cut the rubber for a bicycle tube tha tis what i am doing its about the same thickness.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73GTS Quote  Post ReplyReply Direct Link To This Post Posted: 15-July-2011 at 1:15AM
Would something like this work??
Britech U Channels - Profiles
Do you know the size you are looking for?
If so Click
HERE for Britech's U Channel Finder.
Many tubes, cords, squares, rectangles provided at no tooling charge.
The Below Profiles are all D =Dense Rubber Compound
U Channel # X-396
X-396
U Channel # X-591
X-591
U Channel # X-1274
X-1274
U Channel # X-270
X-270
U Channel # X-1035
X-1035
U Channel # X-200
X-200
U Channel # X-533
X-533
U Channel # X-923
X-923
U Channel # X-1142
X-1142
U Channel # X-650
X-650
U Channel # X-1277
X-1277
U Channel # X-1174
X-1174
U Channel # X-1054
X-1054
U Channel # X-1015
X-1015
U Channel # X-1055
X-1055
U Channel # X-972
X-972
U Channel # X-892
X-892
U Channel # X-541
X-541
U Channel # X-540
X-540
U Channel # X-211
X-211
U Channel # X-758
X-758
U Channel # X-1048
X-1048
U Channel # X-218
X-218
U Channel # X-181
X-181
To Britech Rubber Parts Home Page
Jump to Britech Rubber Products Page
About Britech Industries Rubber Parts
Contact Britech via telephone, fax or e-mail
For more information or RFQ for rubber parts
Sign up for our e-mail newsletter
< id=ccoptin style="MARGIN-BOTTOM: 3px" name=ccoptin =http://visitor.constantcontact.com/d.jsp method=post>Join our list
Email: < style="BORDER-RIGHT: #999999 1px solid; BORDER-TOP: #999999 1px solid; FONT-SIZE: 10px; BORDER-LEFT: #999999 1px solid; BORDER-BOTTOM: #999999 1px solid; FONT-FAMILY: Arial" size=14 name=ea> < =submit style="FONT-SIZE: 11px; FONT-FAMILY: Arial,Helvetica,sans-serif" =submit value=Join name=go> < = value=1102827911048 name=m> < = value=oi name=p>
U Channels
Grommets
Seals & Gaskets
Silicone Rubber
Ribbed Stock
D Sections
Bumpers
Pedestal Sections
P Sections
Triangle Sections
Coves and Wipers
Washers
Recovery Sponge Rubber
Bar Stock
Stopper & Tips
Suction Cups
Rectangles & Squares
Custom Vinyl Extrusions
Injection Molded Plastics
Terms
  Go to Britech Custom Plastics Pages Go to our Complete Rubber Products Page
Sorted by:
Slot Width
Column
Britech
U Channels
Part Number
Guide
How to measure "U" Channels
Match dimensions in the figure to the left with the appropriate column in the chart below.
A = Slot Width
B = Leg Width
C = Overall Width
D = Slot Depth
E = Base Depth
F = Overall Depth
A B C D E F
Slot
Width
Leg
Width
Overall
Width
Slot
Depth
Base
Depth
 Overall
Depth
Britech
Part No.
1/32
1/32
3/32
3/16
1/32
7/32
X-892
1/32
1/16
5/32
5/32
1/32
3/16
0
X-142
1/32 1/8 9/32 9/32 3/32 3/8   X-1035
1/32 5/32 11/32 1/2 3/16 11/16 0 X-270
3/64 1/32 7/64 1/8 1/32 5/32   X-661
3/64 1/32 7/64 1/8 1/32 5/32   X-1142
3/64 1/16 11/64 5/16 1/16 3/8 0 X-200
3/64 1/16 13/64 19/64 5/64 3/8   X-1174
3/64 7/64 17/64 9/32 3/32 3/8   X-591
1/16 1/32 1/8 5/32 1/32 3/16   X-538
1/16 1/32 1/8 13/64 1/16 17/64   X-945
1/16 1/32 1/8 21/64 3/64 3/8   X-1247
1/16 3/64 5/32 5/32 5/64 15/64   X-650
1/16 1/16 3/16 1/8 1/8 1/4   X-195
1/16 1/16 3/16 5/16 1/16 3/8   X-172
1/16 1/16 3/16 3/8 1/16 7/16   X-2818
1/16 1/8 5/16 3/8 5/32 17/32   X-1274
5/64 1/16 13/64 5/16 1/16 3/8   X-396
3/32 3/64 3/16 17/64 3/64 5/16   X-379
3/32 1/16 7/32 1/8 116 3/16   X-566
3/32 1/16 7/32 1/4 1/16 5/16   X-1054
3/32 1/16 7/32 1/4 1/16 5/16   X-541
3/32 5/64 1/4 7/16 3/16 5/8   X-129
7/64 1/16 15/64 17/64 * 27/64   X-1048
1/8 1/32 3/16 7/16 1/16 1/2   X-830
1/8 3/64 7/32 11/64 3/64 7/32   X-693
1/8 3/64 7/32 13/64 3/64 1/4   X-299
1/8 1/16 1/4 1/4 1/16 5/16   X-102
1/8 1/16 1/4 1/4 1/16 5/16   X-540
1/8 1/16 1/4 1/2 1/16 9/16   X-1015
1/8 1/16 1/4 9/32 1/16 5/8   X-874
1/8 1/16 1/2 3/8 1/8 5/8   X-972
1/8 3/32 5/16 9/32 3/32 3/8   X-526
1/8 3/32 5/16 3/8 1/8 1/2   X-688
1/8 3/32 5/16 13/32 3/32 1/2   X-533
1/8 1/8 3/8 3/8 1/8 1/2   X-758
1/8 7/32 9/16 23/32 9/32 1   X-923
3/16 1/16 5/16 1/4 1/16 5/16   X-1146
3/16 1/16 5/16 3/8 1/16 7/16   X-341
3/16 3/32 3/8 1/2 * 3/4   X-1055
3/16 1/8 7/16 3/8 1/8 1/2   X-211
1/4 1/16 3/8 7/32 1/16 9/32   X-770
1/4 1/16 3/8 5/16 1/16 3/8   X-836
1/4 1/16 3/8 3/8 1/8 1/2   X-190
1/4 1/8 1/2 1/2 1/8 5/8   X-982
We gladly accept credit cards
MasterCard and Visa
© Britech Industries All pricing and specifications to be verified at time of ordering.
Web Design & e-mail marketing by
LG Design Problems? Contact the Webmaster. Thank you.
Edited by 73GTS - 15-July-2011 at 1:17AM
Jim
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 15-July-2011 at 1:16AM
This | Big smile
   I know Jim but Starsky Torino said to check the Mustang suppliers as they sell it in strips and read you checked them so was asking for a link
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 15-July-2011 at 1:25AM
Jim you know that BriTech Industries address is 15 Minutes from where I live.It is in Stuart just east of me over the Bridge,LOL and yah if you find out what thickness and depth one of those might work
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73GTS Quote  Post ReplyReply Direct Link To This Post Posted: 15-July-2011 at 2:25AM
I'll try and dig up an old one when I get home and post. Yeah, I tried a few Mustang places with no luck. (unless I was doing something wrong)
A link would be sweet.
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Psquare75 Quote  Post ReplyReply Direct Link To This Post Posted: 15-July-2011 at 2:52AM
The little nylon sliders for the headlight buckets are the same on most Fords of the 70s.. Got any local 'yards?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73GTS Quote  Post ReplyReply Direct Link To This Post Posted: 15-July-2011 at 5:06AM
None of the yards around here have any old cars. I was thinking of going to Lowes and looking. They sell "Christmas trees" for Ford, Dodge, Chevy etc. In the bolt isle. May be able to match something up that might work.
Edited by 73GTS - 15-July-2011 at 5:09AM
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73GTS Quote  Post ReplyReply Direct Link To This Post Posted: 15-July-2011 at 12:22PM
Bingo!!!
Here's what I found.
Whats In My Cart?
Product(s)Price Per.Total
67-312067-3120
$8.10$8.10
71-350471-3504
$13.20$13.20
72-363672-3636
$5.90$5.90
71-345571-3455
$12.30$12.30
72-365072-3650
$7.90$7.90
73-388573-3885
$7.00$7.00
77-446877-4468
$10.10$10.10
77-446277-4462
$16.40$16.40
70-341470-3414
$19.60$19.60
Total: $100.50
Continue ShoppingCheckout
Edited by 73GTS - 15-July-2011 at 12:29PM
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73GTS Quote  Post ReplyReply Direct Link To This Post Posted: 15-July-2011 at 1:00PM
U Channel # X-541
X-541
U Channel # X-540
X-540
Sorted by:
Slot Width
Column
Britech
U Channels
Part Number
Guide
A = Slot Width
B = Leg Width
C = Overall Width
D = Slot Depth
E = Base Depth
F = Overall Depth
A B C D E F
Slot
Width
Leg
Width
Overall
Width
Slot
Depth
Base
Depth
 Overall
Depth
Britech
Part No.
I'm pretty sure 1 of these 2 will work. I just need to find my calipers to get a more accurate measurement.
I tried shortening up this post.......that's the best I can do.Embarrassed
Edited by 73GTS - 15-July-2011 at 1:14PM
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote starskytorino Quote  Post ReplyReply Direct Link To This Post Posted: 15-July-2011 at 4:30PM
www.autokrafters.com,also national parts depot, and dearborn classics.com  they have them for mustangs and torinos and fairlanes
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73GTS Quote  Post ReplyReply Direct Link To This Post Posted: 15-July-2011 at 5:01PM
Been there, done that. If they have them, post a link.
Jim
madmaxtorino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote madmaxtorino Quote  Post ReplyReply Direct Link To This Post Posted: 16-July-2011 at 2:12PM
THEY ARE ON PAGE THREE OF THE 2010  AUTOKRAFTERS FAIRLANE TORINO CATALOG Unhappy
part no domz-16d130a 4.95 a pair  listed for 70 71 torino you can download the catalog from there website it shows a very good picture should be the same for 72 up
Edited by madmaxtorino - 16-July-2011 at 2:14PM
Allan
Revelation 6:8
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73GTS Quote  Post ReplyReply Direct Link To This Post Posted: 16-July-2011 at 2:52PM
That is it. I am just wondering if these are specifically molded for  for the 70-71. There's no listing for the 72-up. How do I know these would work for the 72-up? 72 is different from 73-76 also. It can't be any more ($) to get a length of what I found and make my own.Confused
Jim
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 19-July-2011 at 3:42AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73GTS Quote  Post ReplyReply Direct Link To This Post Posted: 19-July-2011 at 5:41AM
Thanks, those were the easy things to find
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote 73GTS Quote  Post ReplyReply Direct Link To This Post Posted: 19-July-2011 at 10:45AM
OK I contacted AK. They take there good ol' time. Here's what they said.
"These are straight pieces of rubber that are u shaped and are about 8-12 inches long.
thanks,
Brent"
From this response I'm going to assume the will work on the 72-76 as well. I will measure a 70-71 and a 72 and 73 and see if they're the same. (73-76 being the same) I will post.
Thanks for the heads up!
Jim
