four speed 72-73 rear end ratios |
Author | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Posted: 31-January-2012 at 9:14AM |
Ok, for those not paying attention to my current debacle, I lunched an axle on the GTS.
For now, working on getting a replacement axle. This is moving up the axle project for my 76 9 inch build up. I need to also rebuild the trackloc carrier I have, and could use advice on it. Question begs, in a 4 speed car, what were the standard gear ratios for a Q code? Mine was factory 3.50 gears. Fun to drive in town. Crappy on the highway at 80mph. While I love the 2.75's for the highway I currently have, it's too much for the local driving. Plus, burnouts are pretty well a moot thing. Thought about the 3.25 center chunk I have and using the gears off it, but just looking for suggestions for something more road friendly so I am not spinning the engine too much on the highway. Like not 4k rpm at 80 type of gearing. I would love to find something in the 3.10 range, but may end up going with the 3.25's I have sitting in the shed. Just want to make sure anything i should keep a look out for in this fun. Thanks as usual for help. Andrew
Edited by Eliteman76 - 31-January-2012 at 9:16AM |
Pondering: #99Problems |
Psquare75
I only speak from autos.. I love the 3.00s in the '77, but I don't really beat on my stuff.
I need more than a 3.00...like you said in the past, I need a 5 speed, but that is out for now.
Well, more like a t56 and 4.11's...
72GTS351CJ
In my 4spd Torino I have 3 25 with a 275 60 tire. I wouldn't change it for anything else. 75mph under 3k on the tach.
72GTS Clint Eastwood Special
That sounds like a good combo. I was going to suggest a 3.00, but Paul beat me to it.
lynchster
Apparently I missed that. Wheel hopped and broke the right side I presume?
I pulled that feat over lunch one day with a 4.11 posi I had bought just to see if I liked it.
My own fault all the way. In looking at the axles before I reinstalled them we saw all of the fractures at the splines and we all knew I was doomed to failure at one point.
Anyhow. Are you considering an upgrade to either 31 or 35 spline axles? I think the 72 rear is limited to 31 spline but the 76 might be good to 40. Edited by lynchster - 31-January-2012 at 10:20AM |
iangj
Senior Member Joined: 06-March-2009 Location: Fonthill, ON Status: Offline Points: 1019 |
The only 4 speed rear ratio's we have records for on the MGT are
3.25:1 3.50:1
Ian Glyn-Jones
Fonthill, Ontario, Canada Wish I had My Baby Back Montego GT Registry Forum; http://mmgt.forumchitchat.com/ |
Chuck, thankfully, NO!
Only toasted the bearing. Both the inner and outer races split in two. I posted a bit more in my progress thread. According to what I discussed with Currie today, as long as the locking is firmly in place, I am ok. So, I am saying I am OK. Still, I am seriously now considering the '76 housing as a project this year. I have all the parts to piece it together, except a rebuild kit, which is something I am going to look at buying. I need to dig out the 3.25 center chunk, and see what shape it's in. If the gears are worn smooth, don't know if I want to reuse them.
lynchster
If the center section is still good you can wash everything down, throw in some bearings and run it until you decide what you want to do.
JimW
Senior Member Joined: 09-December-2003 Location: USA Status: Offline Points: 602 |
Check ebay for Nascar take out gear sets. They have all sorts of odd ratios. (I have 4.00:1 in my car)..
1976 S&H Gran Torino
460/C6/4.33 13.05@105.6 545/C6/3.56 11.52@117.8 More to come!!!! 463rwhp/495rwtq two tons of fun see it and hear it at: www.torinocobra.com www.st |
picon3
Senior Member Joined: 20-February-2007 Location: North Carolina Status: Offline Points: 2095 |
For 1972 with the 351-4V (CJ) motor, the standard rear axle ratios with the 4 speed manual was an open 3.50. Optional was an open 3.25 or traction-lok 3.25 with the 3.50 traction-lok also an option on early 1972 cars only. Paul~
1972 GTS 351CJ-4V black/black
picon3
The Power Team selections show the engines, transmissions and axles that could be ordered together.
"Not available in California with manual transmission. NA‑Not Available |
Thanks Paul.
Another bit of info, was the nodular center sections. I can not vouch for the automatic cars, but from my understanding Q codes with the top loader were given the Nodular center section {"N" case}. Still need to dig out the '74 3.25 Q code assembly. |
iangj
Yes. Of the dozen or so that I have personally seen, the 4 speed cars had the "N" case with either 3.25 or 3.50 gear if they were lockers.
Mine is an "N" case 3.50:1 4 pinion 28 spline TracLoc Edited by iangj - 01-February-2012 at 9:19AM |
Ian Glyn-Jones
stanman
My car is Q code, 4-speed, "N" case, 3:50 Trac-Loc also.
stuck
Senior Member Joined: 23-December-2007 Location: michigan Status: Offline Points: 279 |
early with 3.50 not N . you can bet I will look again even though I know it is not. looks original because of undercoating and tag.
Edited by stuck - 01-February-2012 at 10:50AM |
michigan
lynchster
Mine is a N case 3.50 peg leg.
stuck
I forgot to say trac-loc
michigan
I was really surprised with the 4 speed, it did not get ordered as such.
I mean, my car has been a oddity from the get go. The PO had informed me original front brakes were the larger 12 inch rotors from ford. How in the heck did that happen? |
I firmly believe that back when these cars were made, you could practically order them ala carte.
picon3
Edited by picon3 - 02-February-2012 at 3:53AM |
That burger looks as good today as it did then! Yum.
lynchster
I just got off of the phone with Currie because I wanted new axle retainers and they had 1/4" enclosed ones as opposed to the "U" shaped ones from Strange and Moser. Anyway I was talking to Travis about the benefit of swapping to the large bearing rear once I go to put the original engine back in. Here's what I learned for anyone else who doesn't know.
- The benefit is not in bear size but in the design. Small bearing rears use ball bearings the large bearing rear uses or can use tapered bearings.
- The large bearing rear can support 35 spline axles but limits center section availability. (?)
- 31 spine axles (theirs) can support 750 horsepower. I wonder why they aren't torque rated.
Anyway since we use this as a collective knowledge base - there's some info.
Edited by lynchster - 13-February-2012 at 4:19AM |
