Project TV 2M8O |
Post Reply | Page <1 1718192021 42> |
Paul100ca
Senior Member Joined: 21-November-2014 Location: Ontario, Canada Status: Offline Points: 315 |
nice...
Nothing stops this train.
TV 2M8O
second coated the transmission crossmember with the Eastwood Rust Inhibitor... blasted a few parts... and worked on the floor insulation taping some areas that needed addressed. Will be out of town next weekend for the Memorial Day holiday, but will be taking a few vacation days the following weekend (originally to attend Carlisle) to try and make some REAL progress on the Tomato. Wish me luck! Edited by TV 2M8O - 22-May-2016 at 8:46AM |
you should be close to having it "rollable" again soon, right?
TV 2M8O
Yeah, waiting to get my wheels back from the polishers and get the rubber mounted and she'll be mobile once more!
TV 2M8O
**CLICK ON PICS TO ENLARGE AND CLICK AGAIN TO SUPERSIZE** Well got the wife's garden cart "restoration" completed this weekend.... blasted the drive shaft... got it, the transmission crossmember and core support painted... repaired a thin spot in the timing cover I found after sandblasting it... pulled out all my new gaskets and engine parts to make sure I had the majority of them ready for installation... and started removing the accessories and brackets from my original 460 to get them cleaned, prepped and detailed for reassembly onto my new engine. Next weekend I hope to finish cleaning the block and start final install of the oil pan, timing cover, water pump, intake manifold, the OEM valve covers (until I can get the MT covers spread a bit to fit the heads) and get a couple coats of dark Ford blue applied. Eager to get the engine buttoned up and installed so I can do a quick start to insure she's ready to roar back to life!
Edited by TV 2M8O - 07-June-2016 at 2:29PM |
nice!
mlachance112785
Senior Member Joined: 31-May-2012 Location: Dighton, MA Status: Offline Points: 343 |
Looks great Joe. Gives me the motivation to sandblast my radiator support, inner fenders, and get them painted while I wait to get the motor back from the machine shop.
On that oil pan gasket, if it is the same as the Felpro one piece, you have to drill out/enlarge the hole on each corner. If that makes sense. Disregard if you already knew this.
77 Cougar XR7 460/C6
TV 2M8O
Mark, It's the Ford Motorsport one piece pan gasket... I'll keep an eye open for the hole sizes! THANKS
hey joe, since you've had the car apart so long now... are those new gaskets now considered NOS (sorry couldn't help myself ) you're making some major progress now! i can't hardly wait
mlachance112785
Joe, I thought I already pitched my old gasket. Guess not. Here's a couple pictures of the gasket and where I had to drill.
If I remember correctly: while drilling, the bit will catch and almost (for lack of a better word) "rip" the metal washer out of the gasket. I just used a dab of copper Permatex in each hole to prevent leaks. Hopefully the Ford Racing/Motorsport gasket is already provisioned for the earlier big blocks.
TV 2M8O
Mark.... if the Motorsport gasket doesn't have the enlarged hole already, I have a set of gasket punches which should make it an easy modification!
Again, thanks for the heads up!
TV 2M8O
**CLICK ON PICS TO ENLARGE AND CLICK AGAIN TO SUPERSIZE** Well Saturday was a real test of stamina and determination! Must have been 110 degrees upstairs at the dealership (Man sweat really BURNS when it gets into your eyes! LOL) but I kept plugging away until I got everything pulled off my original engine... made a "map" of where the different bolt sizes go on the water pump/timing cover (Ya know what's funny... I have three 460 engines and only ONE set of water pump/timing cover hardware! WTH??? Guess I'll be placing an AMK order!).... and started blasting some of the hardware.
Edited by TV 2M8O - 12-June-2016 at 12:23PM |
i see more blasting in your future, joe
TV 2M8O
Yes, but some of my original engine components simply need degreasing and maintain the original finish. I degreased my clutch fan years ago when I first got the car and it cleaned up pretty nicely, so perhaps I'll only be blasting brackets... Time will tell!
TV 2M8O
Well got the drive shaft cleared... and started putting the 460 together... got the timing cover, water pump and oil pan installed and the exhaust ports masked so I can get the engine painted. I started cleaning the power steering hard lines before calling it (another sweltering day!). Edited by TV 2M8O - 18-June-2016 at 10:50AM |
soon!
TV 2M8O
**CLICK ON PICS TO ENLARGE AND CLICK AGAIN TO SUPERSIZE** Evidently AMK doesn't have the long flange head bolts needed for the water pump hardware so I ordered some washers the correct OD from Fastenal to use with the supplied bolts so I could keep moving forward. I got the lower section of the 460 primed.... then first coated... and rehung the driver's door... and blasted a few brackets and pulleys to get ready to rehang on the engine once it's back in the car. I also broke down an old set of tires to blast and clean up the rims to see if they would seal with some old tires and hold air for use as rollers for the Tomato when she goes back to the guys at Far From Factory for final bodywork and paint..... SOON I HOPE!! Edited by TV 2M8O - 26-June-2016 at 7:42AM |
it's starting to look like a car again joe!
Paul100ca
beauty...
TV 2M8O
Well got the 460 rolled over to assemble the top side... cleaned the gasket surfaces... chased all the tapped holes... installed the intake studs... and dry fit the intake before installing the gaskets and RTV along the front and rear end seals.... SO top side assembly and paint stalled until the necessary nipple can be gotten.... but I did go ahead and coat the intake manifold gasket and set it in place so that much will be ready once I get the nipple and wrap up the intake installation. HAPPY FOURTH TO ALL MY FELLOW TORINOITES!
Edited by TV 2M8O - 02-July-2016 at 10:56AM |
that sucks joe, those things are generally pressed in, so if you find the right one you'll probably have to remove the pump and press it in. good news is... you haven't run the engine so the pump should come off without tearing the gasket!
starsky460
Senior Member Joined: 01-April-2010 Location: Ply Meeting PA Status: Offline Points: 209 |
Looking good Joe !!!
Carl
1976 Gran Torino Starsky & Hutch Limited Edition FACTORY 460 c.u. engine 3:55 gears |
TV 2M8O
Ordered this for pickup next weekend from Summitt while I'm in Tallmadge...
ah, i was going to suggest maybe treading it would be easier! looks like you got it figured out
TV 2M8O
and intake painted. This weekend, bypass hose nipple installed, intake dry fit... intake installed... bypass hose and clamps installed and masked, water pump reinstalled then top side of engine painted... finally, distributor installed and carb dry fit before calling it a (sweltering!!) day. Until next week........ Edited by TV 2M8O - 23-July-2016 at 11:40AM |
Dan the ranchero man
Looks great! Stay cool brother!
"until next week..." are you dropping it in???
TV 2M8O
Still a few more items I want to hang on the engine before setting it in the car, but my plans are to have it back between the frame rails next weekend!
TV 2M8O
Well a day of regression.... was getting my all my stuff together to mount my harmonic balancer and guess what I found in the Ziploc bag will all the hardware and woodruff key? The damn oil slinger for the timing chain! Jumped on line to see if it was a necessity and a couple of the sites I trust both said "don't forget to reinstall the oil slinger", so two weekends of work went out the window as I broke everything down to access the timing set! At least I know things are in order, LOL, and there will be plenty of paint on the 460 by the time it gets installed!! I also rebuilt my AC idler pulley because the bearing seized up when I blasted it. I was surprised that the original bearing said JAPAN on it... but I guess by the mid '70s things had already begun to move offshore. A bead of RTV to seal the outer cover back on and I will do a bit of beautification on the visible side to make it more appealing before spraying it satin black to match the other pulleys.
Next weekend, I plan on installing the engine mounts, rolling the engine over and touching up the top side before dropping the 460 into place. Wish me luck......... Edited by TV 2M8O - 31-July-2016 at 8:34AM |
