  New Posts New Posts RSS Feed - The Junkyard Photo Thread
 Post Reply Post Reply Page  <1 2930313233 38>
Post Options Post Options   Thanks (0) Thanks(0)   Quote GTW Quote  Post ReplyReply Direct Link To This Post Posted: 01-March-2016 at 8:34AM
Salvage 1974 Gran Torino Elite - Sacramento, CA - 4G21H277223 - Auction date: Not set
Now on Craigslist: http://sacramento.craigslist.org/cto/5469732648.html
Post Options Post Options   Thanks (0) Thanks(0)   Quote GTW Quote  Post ReplyReply Direct Link To This Post Posted: 03-April-2016 at 4:29AM
Everything except the header panel was crushed:
mach1000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mach1000 Quote  Post ReplyReply Direct Link To This Post Posted: 26-April-2016 at 11:45PM
Mach1000
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 27-April-2016 at 10:27AM
That rear bumper looks pretty good on that one!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 27-April-2016 at 11:36AM
Yeah, and someone left a bag of tools in the front seat too...
Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote mach1000 Quote  Post ReplyReply Direct Link To This Post Posted: 27-April-2016 at 12:54PM
Bumper wasnt too bad. Someone put a trailer hitch on it so it was tweaked some. I managed to get a few parts off it but someone already took the axle, rear sway bar, gauges cluster and bezel and a few other things.
Mach1000
n2fordwagons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 28-April-2016 at 1:06AM
How near is this Ranchero to you?  Any chance you can get that trim piece above the glove box door for me?  If it's at a reasonable price, and in decent shape?
Jeff
71 Torino Brougham
72 Gran Torino Squire
Post Options Post Options   Thanks (0) Thanks(0)   Quote mach1000 Quote  Post ReplyReply Direct Link To This Post Posted: 28-April-2016 at 1:16AM
Its near by. I didn't get it because its busted up. The tabs were broken off and the mounting studs broke. It is the engine turned finish too..
Mach1000
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 28-April-2016 at 1:34AM
Ok.  Thanks.  I've already got a decent one.  But figured I could use an extra, if it was in decent shape.  I'm converting my '79 Tbird to the engine turned finish.  I'm also looking for the smaller engine turned trim surround pieces, on each side of the steering column.  The one that surrounds the heater controls, and the one that surrounds the radio.  I can't tell from the pics if those were there and in decent condition.
Edited by n2fordwagons - 28-April-2016 at 1:35AM
Jeff
71 Torino Brougham
72BlackGTS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72BlackGTS Quote  Post ReplyReply Direct Link To This Post Posted: 02-May-2016 at 10:59AM
Thats the color of my interior. Dash pad was no good Im guessing.
Ron
1978 LTD II Sport-Green
Post Options Post Options   Thanks (0) Thanks(0)   Quote mach1000 Quote  Post ReplyReply Direct Link To This Post Posted: 02-May-2016 at 11:08AM
Dash pad was cracked and split in a couple areas.
Can't recall if engine turned pieces on each side of the column were there. Are they glued on the backside? Or how are they removed if there and decent?
Seat actually was good. Didn't see any rips but a seat does not ship well $$$$ if someone wanted it.
Edited by mach1000 - 02-May-2016 at 11:10AM
Mach1000
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72BlackGTS Quote  Post ReplyReply Direct Link To This Post Posted: 02-May-2016 at 11:13AM
I would be interested in the arm rests if there. I'd like to find some non sun bleached seat belts in that color too but i see those are like mine, faded out.
Ron
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 02-May-2016 at 1:25PM
As far as I know, the engine turned pieces are held on by screws, up under the upper part of the dash.  I'm not sure what else holds it on.  Here's a pic of an NOS one, as an example.  I've never tried to remove one, so I'm not 100% sure what all is involved.
Jeff
71 Torino Brougham
Post Options Post Options   Thanks (0) Thanks(0)   Quote mach1000 Quote  Post ReplyReply Direct Link To This Post Posted: 02-May-2016 at 1:27PM
Ill take a look next time Im there on the dash pieces.
Seat belts were faded and worn.
Mach1000
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 03-May-2016 at 12:22AM
Thanks, I appreciate it.
Jeff
71 Torino Brougham
mcford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mcford Quote  Post ReplyReply Direct Link To This Post Posted: 03-May-2016 at 8:59AM
ITS PRBABLY THE SAME AS THOSE WITH THE WOODGRAIN.  TABS THAT STICK THROUGH SLOTS IN THE DASH AND ARE BENT OVER ON THE BACKSIDE OF THE DASH.
drb2018 View Drop Down
Brand New Member
Brand New Member
Post Options Post Options   Thanks (0) Thanks(0)   Quote drb2018 Quote  Post ReplyReply Direct Link To This Post Posted: 24-May-2016 at 3:11AM
Is the 1970 already gone?
Post Options Post Options   Thanks (0) Thanks(0)   Quote GTW Quote  Post ReplyReply Direct Link To This Post Posted: 25-May-2016 at 6:49AM
Salvage 1979 Ranchero 500 - Greer, SC - 9H47F172292 - Current bid: $350
Post Options Post Options   Thanks (0) Thanks(0)   Quote GTW Quote  Post ReplyReply Direct Link To This Post Posted: 25-May-2016 at 6:50AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote GTW Quote  Post ReplyReply Direct Link To This Post Posted: 25-May-2016 at 6:52AM
Salvage 1972 Montego - Kansas City, KS - 2H07H583029 - Current bid: $0
Post Options Post Options   Thanks (0) Thanks(0)   Quote GTW Quote  Post ReplyReply Direct Link To This Post Posted: 25-May-2016 at 7:05AM
Salvage 1978 Thunderbird - Martinez, CA - 8G87H286803 - Current bid: $200
Post Options Post Options   Thanks (0) Thanks(0)   Quote GTW Quote  Post ReplyReply Direct Link To This Post Posted: 25-May-2016 at 7:07AM
Salvage 1979 Thunderbird - Montgomery, AL - 9J87H188214 - Current bid: $60
Post Options Post Options   Thanks (0) Thanks(0)   Quote GTW Quote  Post ReplyReply Direct Link To This Post Posted: 25-May-2016 at 7:11AM
Salvage 1978 Thunderbird - Dallas, TX - 8J87H140856 - Current bid: $0
Post Options Post Options   Thanks (0) Thanks(0)   Quote GTW Quote  Post ReplyReply Direct Link To This Post Posted: 25-May-2016 at 7:15AM
1970-71 Montego four door sedan located in Richmond, CA at PICK-n-PULL Richmond
Post Options Post Options   Thanks (0) Thanks(0)   Quote GTW Quote  Post ReplyReply Direct Link To This Post Posted: 25-May-2016 at 7:26AM
What were salvage photos of a 1974 Gran Torino S&H replica
Edited by GTW - 27-December-2016 at 11:17AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote GTW Quote  Post ReplyReply Direct Link To This Post Posted: 25-May-2016 at 7:41AM
What were salvage photos of a 1973 GTS Q code 4 speed
Edited by GTW - 27-December-2016 at 11:18AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote GTW Quote  Post ReplyReply Direct Link To This Post Posted: 25-May-2016 at 7:57AM
What were salvage photos of a 1972 base Torino 250 3 speed with a 74-76 front clip
Edited by GTW - 27-December-2016 at 11:19AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote GTW Quote  Post ReplyReply Direct Link To This Post Posted: 25-May-2016 at 8:06AM
What were salvage photos of a 1979 Ranchero 500
Post Options Post Options   Thanks (0) Thanks(0)   Quote GTW Quote  Post ReplyReply Direct Link To This Post Posted: 27-May-2016 at 9:10AM
jhggtsf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhggtsf Quote  Post ReplyReply Direct Link To This Post Posted: 13-July-2016 at 11:31AM
This 1974 Elite looks quite intact for a totaled car. A 460 according to the VIN.
This page was generated in 0.516 seconds.
