Unidentified item on starter relay |
Gazoo2
Member Joined: 14-September-2010 Location: Calgary,Alberta Status: Offline Points: 63 |
Posted: 09-May-2013 at 6:17PM |
There is a small stamped-tin-cased electrical device attached to the battery-cable-side lug of the starter relay on my 72. It has two screw lugs on the back. The wire leaving one of the lugs is a heavy, maybe #14 black wire with white or yellow stripe that leads into the main harness running to the firewall fuse box connectors. There is nothing attached to the second lug. What is this thing?
It sort of resembles an instrument cluster voltage regulator and is about the same general size, but I don't think that is right. |
72 GranTorino "rat wagon" 351C, a work in progress
69 Mustang Mach 1, 351w, Borg Warner T5, rack & pinion steering, fuel injected |
GranTorinoSport
Do you have an aftermarket tachometer?
Webmaster |
TV 2M8O
Any markings on the device? How about a picture??
fordnmerc
Senior Member Joined: 21-May-2003 Location: Watkins Glen NY Status: Offline Points: 877 |
I was immediately reminded of the emergency starters that were installed on cars built in Canada, such as at the Oakville assembly plant. Our 1974 Torino had one of those units.
Does it have what looks like a large orange button on it? I've seen some that were mounted upside down, so the button might not be easily visible if it's on the underside and not easy to get at.
David
rear defrost circuit breaker?
Robbdtme
Senior Member Joined: 06-June-2012 Location: Central WI Status: Offline Points: 765 |
It is a automatic reset circuit breaker old ford type. |
TV 2M8O
I was thinking the same thing as Robb ... circuit breaker, but want to see a pic to be sure I was correct.
Gazoo2
Sorry, I had to be away for a couple days. I'm trying to attach a pic to this message.
GranTorinoSport
This is a thread started by PSquare75 about some various ways to post photos. Please review and if you have any difficulties PM one of us for additional assistance.
Webmaster |
TV 2M8O
Is this the device you are questioning............
20A circuit breaker. In my case for rear window defroster. Hope this clears up the mystery!
gpd294
In my case it was for the rear power window in the tail gate of my wagon. Hope this helps!
Gazoo2
Yes, thank you both - doing some research today I also determined it is a circuit breaker. I found a wiring diagram for a 73 that shows it supplies the power rear window on my wagon. Thanks for your help everyone!
