  New Posts New Posts RSS Feed - Cheap Cadillac Flips easy $$$$
Robbdtme View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbdtme Quote  Post ReplyReply Direct Link To This Post Topic: Cheap Cadillac Flips easy $$$$
    Posted: 02-September-2013 at 6:03PM
ALRIGHT Easy and flipped enough of these, Just flipped another today. Shops quote a new transmission needed.
Cadillac with bad transmission and service engine light on. Car has only 3rd gear forward starts and stops in it no manual 1or 2 or overdrive, Reverse works normal.
AC Clutch is shot and blows fuse 1 15 amp in the secret 4th Cadillac fuse panel not in any manual, Below the glovebox remove 4 7mm screws and to the right you find a 4th fusebox. replace fuse 1 and cut or pull ac Clutch wires. Otherwise first time ac  clutch tries to engage fuse blows again. I picked up caddys for years at 500 bucks each and flipped em with this problem.  Bought this one for 400 and sold it 3 hours later for 2,500. Did change the oil and plugs so had 450 in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 03-September-2013 at 1:58AM
So replacing the A/C fuse corrects the transmission issue?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbdtme Quote  Post ReplyReply Direct Link To This Post Posted: 03-September-2013 at 4:49AM
Transmission is electronically controlled
robot9000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robot9000 Quote  Post ReplyReply Direct Link To This Post Posted: 03-September-2013 at 5:09AM
So the trans is on the AC ckt? No wonder they struggle LOL
2010 Mazda 6
2007 Jeep Wrangler
2011 Damon Daybreak 35BD
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 03-September-2013 at 5:16AM
I know a guy here that buys the later model Cadillacs with blown head gaskets. Gets them for anywhere from $500 to $800. Drops the engine cradle, installs Ford head bolts, new gaskets, pops the cradle back in and sells the fire out of them. NICE cars that rarely have that issue ever again and he makes a great living doing that and can do several a week.
