Frame Paint |
Posted: 12-June-2018 at 2:11PM |
I am looking for opinions on chassis paint. I am stripping the front frame section on my car and I want to repaint it with the best quality paint I can. So far the frame is pretty well rust free, but there are some areas with very light surface rust (no pitting). Once I have finished removing the undercoat, have a HVLP spray gun that I borrowed, so I can shoot it in my garage. I am a complete newbie at using a spray gun, but I am very good with a rattle can. CalifoniaJohnny suggested SEM's Rust Shield paint, which looks to be great stuff. Paint right over metal and rust, no primer and doesn't need to be top coated. It can be sprayed or brushed. It seems to have a good reputation for the most part. The problem is, I can't seem to get the stuff anywhere! Even the SEM dealer closest to me says he can't get it (or is unwilling). I have one more paint supply guy that says he might be able to get it, but only in the gallon size, which is probably way too much. He will get back to me soon. The only other option I looked at was Eastwood's paints. I have used there stuff in the past and it's decent, but I think it's probably overpriced (maybe I am wrong). I'd probably used Eastwood's Encapsulator paint as a base and then top it with their extreme chassis paint. It looks like it can only be sprayed. They claim their extreme chassis paint is super durable and hard. I am really not sure if it would be at all better than the SEM stuff I mentioned above, but it does seem more expensive. I was also planning on using whatever chassis paint I pick to paint some of the engine brackets, and other small underhood parts, unless that's not a good idea? Anyone have any opinions or input? Any other good options out there for a decent high quality chassis paint that can stand up to some road use? |
Senior Member Joined: 30-July-2010 Location: On The Road Status: Online Points: 6059 |
Thanks Rock, except it won't ship to my location.
the great almighty amazon won't ship to NA that's a hoot / er .. um ... just about what i expected have it shipped to meet your motor
here's one in a qt size scroll down they say they ship globally!
https://www.ebay.com/itm/SEM-28104-2-8-VOC-Rust-Shield-1-Quart/173255929304?epid=1423662678&hash=item2856dbadd8:g:VnIAAOSwupRaxq-~ |
Lots of stuff on Amazon won't ship up here. Depends on the vendor in a lot of cases, and sometimes with paint products, there is environmental issues. I would like the paint before I get my engine if possible, which is why I just wanted to get it locally.
John, how much do you think I will need? Will a quart be enough? Do you think this stuff will be okay for the engine brackets and some other small bits under the hood? I forgot to check eBay, but it looks like they will ship up here. I just got to watch the extra fees they charge on that global shipping, sometimes it makes it crazy expensive. The body supplier got back to me and he says his SEM supplier won't sell it up here due to no longer meeting the environmental standards. Maybe that's why Amazon won't ship it up here. The Eastwood stuff I can get from a Canadian supplier, so there is no hassle when I have ordered in the past.
Edited by 72FordGTS - 13-June-2018 at 8:04AM |
MrSmog
you have tractor supplies up there? just get the black implement paint, I use gloss as it dulls out fast enough to look like the factory shade.
dave302
These next three sellers are all located in Canada.
https://www.amazon.ca/SEM-28104-2-8-Rust-Shield/dp/B00EDE6YAE/ref=sr_1_1?s=automotive&ie=UTF8&qid=1528935581&sr=1-1&keywords=SEM+28104+2.8+VOC+Rust+Shield http://www.canadiantire.ca/en/pdp/vht-high-temperature-roll-bar-and-chassis-paint-312-g-0473707p.html Edited by dave302 - 13-June-2018 at 1:47PM |
dave302
vince, if you're just doing the underhood area of the frame a qt should do it... yes you can use it on brackets and stuff too
i did my whole frame with a gallon and had a little left over |
dave302
http://www.canadiantire.ca/en/pdp/rust-check-anti-rust-automotive-paint-0477970p.html#spc
http://www.canadiantire.ca/en/pdp/tremclad-rust-paint-semi-gloss-0489210p.html https://www.amazon.ca/GLOSS-BLACK-CHASSIS-SAVER-MPC-UCP99-04/dp/B00EP8BYNK/ref=sr_1_2?s=automotive&ie=UTF8&qid=1528986298&sr=1-2&keywords=chassis+paint++black Edited by dave302 - 14-June-2018 at 3:30AM |
andrewok1
Senior Member Joined: 02-June-2015 Location: OCALA FL Status: Offline Points: 424 |
Vince / this place will ship to you x-tra 70.00 to cross-border , i called and spoke with MANNY
California Johnny is right best stuff to use hardens and almost impossible to scratch once cured,
Edited by andrewok1 - 14-June-2018 at 7:47AM |
GET IT GOT IT GONE !!!!!!!
Thanks guys for all the help, much appreciated! I am going to get the Rust Shield ordered from the States. I found a company that doesn't charge ridiculous shipping.
Edited by 72FordGTS - 14-June-2018 at 11:52AM |
andrewok1
lots of pictures
