  New Posts New Posts RSS Feed - Front pump
Front pump
Postma98 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Postma98 Quote  Post ReplyReply Direct Link To This Post Topic: Front pump
    Posted: 12-July-2017 at 3:04AM
Hey guys, so i pulled the front pump on my mercury to replace the o-ring because it was leaking. I put the new seals back on and put it together. I put my car in nuetral yesaterday to roll it out of the driveway and the transmission was locked up. I pulled my front pump again and found that as i begin to tighten it down it locks up the input shaft and doesnt allow it to turn. Any thought guys?
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 12-July-2017 at 9:02AM
C6?? Does the input shaft have the "dimple" facing toward the engine, the input shaft will go in both ways but it won't fully seat inside the trans if installed with the dimple side installed in the trans. IIRC, the early C6 input shaft will go in either way, but in the later C6's it makes a difference. Another issue is the thrust washer behind the stator support, the thrust washer has a "tang" that locates it in the stator support, if not lined up correctly there will be no end play clearance. Hope this helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 20-July-2017 at 3:29PM
I can tell you on an automatic...you want to spin the converter two different times to seat it in the pump.
Hopefully you didn't crack/damage the pump internals.
Did that on a fresh rebuilt 86 Mustang C5 one time, and not fun installing that trans twice.
Edited by Eliteman76 - 20-July-2017 at 3:30PM
Andrew
