  New Posts New Posts RSS Feed - Front seat removal
Front seat removal
HiTorino73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HiTorino73 Quote  Post ReplyReply Direct Link To This Post Topic: Front seat removal
    Posted: 07-April-2017 at 11:03PM
Hi everyone,
I did search the forums and didn't see the answer so figured I would ask.
I will be removing my seats to install new carpet. Question....I have front bench seats. Can I remove them as one whole piece or do I need to remove the backs off the bench seat? I know they fold down but is it enough to pull out the door? How hard is it to remove the backing of the seats?
Thank in advance.
Every day is a good day, some are just better than others
Post Options Post Options   Thanks (0) Thanks(0)   Quote changinlatitudes Quote  Post ReplyReply Direct Link To This Post Posted: 08-April-2017 at 12:21AM
Nope, it can all be taken out as one piece. Pretty simple. Just push the seat all the way back and take out the front floor bolts, the slide it all the way forward, exposing the rear bolts. You'll have to disconnect the seat belt warning plug under there if you have it. Think it's a pink wire. The male end of the seat belt should slid out from the seat back, or you can just take those out before you take the seat out to inspect and clean them. Those are attached to the transmission hump under the backside of the seat.  It'll help to have somebody assist you taking it out, because it is bulky....but you can do it by yourself.
Matt
1972 Montego MX
2003 Mercury Marauder 300A
2015 Honda Civic Coupe
2016 Ford Fusion Titanium
Post Options Post Options   Thanks (0) Thanks(0)   Quote changinlatitudes Quote  Post ReplyReply Direct Link To This Post Posted: 08-April-2017 at 12:23AM
Oh, with those seat belt ends, you'll need a big torx wrench. Forgot the size, sorry. Hopefully somebody can chime in.
Matt
1972 Montego MX
Post Options Post Options   Thanks (0) Thanks(0)   Quote HiTorino73 Quote  Post ReplyReply Direct Link To This Post Posted: 09-April-2017 at 8:57PM
One quick question for those that have changed them seat belts.
I noticed my top anchor for my seat belts are behind my headliner. Can anyone tell me when I replace the seatbelt will the anchor bracket stay in place behind the headliner or will I need to remove the headliner to install new anchor points?
Thanks in advance
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 10-April-2017 at 2:32AM
no it's part of the roof of the car, just like the one's on the floor
74 CORVETTE COUPE CUSTOM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 10-April-2017 at 9:28AM
Unbolt the seatbelt center parts from the floor and pull out thru the seats before removing the seats.
It's easier with the retractors off too, but not necessary.
fordpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordpower Quote  Post ReplyReply Direct Link To This Post Posted: 10-April-2017 at 1:49PM
Two people will make it a lot easier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HiTorino73 Quote  Post ReplyReply Direct Link To This Post Posted: 10-April-2017 at 4:15PM
Thanks everyone. Made my day, didn't want to fit with my headliner since it is original and in great shape.
This page was generated in 0.059 seconds.
