Fuel tank sending unit |
Jedi
New Member Joined: 12-February-2020 Location: Kelowna B.C. C Status: Offline Points: 28 |
Posted: 12-February-2020 at 1:36PM |
Hi Members,
Just joined the forum, I’m working on a 1970 Mercury Cyclone Spoiler 429 CJ The car hasn’t run since 1989 and I’m in the process of trying to get it up and running again. I’ve done the brakes and have had the heads off and rebuilt, I’m getting close now to trying to start it. Problem right now is I’m looking for a sending unit for the fuel tank, the part number that is stamped on the original is DoOF-9275-D it has two ports, supply and return lines. Hopefully someone might. chime in with a solution Cheers Jim |
Jedi
Thanks Rock for the info
Jim
Jedi
Hi There,
I resurrected the old fuel tank sending unit, hopefully it works ok, time will tell Cheers
