  New Posts New Posts RSS Feed - Fuel tank sending unit
Jedi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jedi Quote  Post ReplyReply Direct Link To This Post Topic: Fuel tank sending unit
    Posted: 12-February-2020 at 1:36PM
Hi Members,
Just joined the forum, I’m working on a 1970 Mercury Cyclone Spoiler 429 CJ
The car hasn’t run since 1989 and I’m in the process of trying to get it up and running again.
I’ve done the brakes and have had the heads off and rebuilt, I’m getting close now to trying to start it.
Problem right now is I’m looking for a sending unit for the fuel tank, the part number that is stamped on the original is DoOF-9275-D it has two ports, supply and return lines.
Hopefully someone might. chime in with a solution
Cheers
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 12-February-2020 at 3:16PM
Jedi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jedi Quote  Post ReplyReply Direct Link To This Post Posted: 12-February-2020 at 5:18PM
Thanks Rock for the info
Jim
Jedi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jedi Quote  Post ReplyReply Direct Link To This Post Posted: 16-February-2020 at 9:59AM
Hi There,
I resurrected the old fuel tank sending unit, hopefully it works ok, time will tell
Cheers
