Fuel & Temp gauge, dash lights |
Post Reply
| Author | |
537ONN
Joined: 07-September-2015 Location: Virginia Status: Offline Points: 8 |
Quote Reply
Topic: Fuel & Temp gauge, dash lightsPosted: 08-September-2015 at 8:18AM |
Heres one for the minds. I have a 75 Gran Torino. 351 W. Im the second owner and about a year after purchase I started having an issue with the dash lights. The lights would flicker then go out. I could tap on the dash and they would come back on. I didn't really get into it because I wanted to swap dash clusters with a Sport. Well before I could do that my fuel & temp gauges went wacky on me. The fuel will read full and the temp would go all the way over to hot. I thought no big deal, its something with this cluster and I had already ordered one. I figured I would change it out and problem solved, well that didn't happen. When I installed the new cluster I had the same issue. Ive done some trouble shooting, pulling the connector off the fuel sending unit (which is a new one) and tested the units IVR. My manual says if the voltage is steady that the IVR is bad. So to eliminate that possibility I plugged the other dash back in and still the same issue. I don't think both IVR's could be bad. Does anyone know what the number ID's on the plug are for ? Im thinking my issue is with the plug going back thru the vehicle and not the dash cluster. Thoughts anyone ?
Quote Reply
Posted: 08-September-2015 at 12:12PM |
does the fuse block look rusty / crusty?
aquartlow
Joined: 19-December-2011 Location: Summerfield, Fl Status: Offline Points: 2341 |
Quote Reply
Posted: 08-September-2015 at 12:18PM |
Could the dash cluster be from a different vehicle, there are differences in the wiring terminations of different year gauge clusters and/or plugs. This may help:
it shows the differences in model years' plugs, hopefully it will help. A bad IVR(or one that is going bad) can have you chasing your tail a bit. Another potential problem area is the printed circuit/printed circuit plug contacts, they can bend/fold over easily and/or break, just have a good look at it when/if you remove the cluster again.
Edited by aquartlow - 08-September-2015 at 12:22PM |
72GTS351CJ
Joined: 30-November-2010 Location: NY Status: Offline Points: 1482 |
Quote Reply
Posted: 08-September-2015 at 12:53PM |
Like Todd said about the circuit board plug. I recently had my guage cluster out and when I reinstalled it nothing was working correctly. I took it back out and had to glue the printed circuit back in its correct position for the plug to mate to its proper circuit. Good luck. .. Rick
72GTS Clint Eastwood Special
Joined: 05-October-2013 Location: winlock, wa Status: Offline Points: 14723 |
Quote Reply
Posted: 08-September-2015 at 6:03PM |
^^^ what they said. you may need to trace down the individual circuits from the plug to the gauge one at a time, you may need to switch a couple of the wires around to match up with the sport cluster (i did on my dash conversion in my car) also--- if your original cluster had idiot lights, you need to change the oil and water senders to a gauge type (there is a difference) they fit the same but use a different resistance value for the gauge vs a light
537ONN
Quote Reply
Posted: 09-September-2015 at 1:29AM |
Thanks a lot CJ, That's what Im kinda thinking that too since I had gauge trouble with the previous dash cluster. Thanks everyone for all your input , I will keep you posted on the progress.
537ONN
Quote Reply
Posted: 09-September-2015 at 2:02PM |
Well heres an update. I had to order a new ignition module as mine died on me after pulling the car in front of the garage door. Well during that time of waiting for the new to arrive I decided to do some more trouble shooting. Seems my plug that goes into the PCB of the cluster is the 77-79 (some 76models) D7GF 10C956 BA. The #1 pin being the purple with white stripe. After installing the ignition module I plugged in the dash cluster and all my dash lights started working. I had switched over to LED's but when I plugged it in earlier nothing would come on. So, maybe the module had something to do with it (sounds unlikely ,but... you never know). I pulled the cluster again after seeing both the fuel and the temp go all the way over. I matched up the pin identifier page I had printed off (from the forum here) to the plug I have and it says its for a 72. So I'm not sure what I have ,lol. Anyways I took my meter and verified I had 12 volts on the plug,then I went to pins 2(red & white) and 10 (white & red). First to 2 and checked it to ground for voltage with the key off, then on. Then check for continuity it both conditions: no reading. The same with pin 10. Then I check for voltage from pin 4 to pin 2 -nothing checked same pins for continuity and I had it both with key on or off. The same condition exist for pin 10 also. All of these checks were done with the fuel sensor plugged in. I unplugged the sensor and got the same readings. I then read between 2 and 10 for continuity and I had it (with the sending unit unplugged). I'm not sure but it sounds like a wire has gone to ground. I tried tracing back the #2 pin & #10 wires to see if any thing had shorted, found nothing there but I did find a wire that was hanging loose at the fuse box,behind it the wire's purple in color with orange dashes on it. I couldn't see where it had come from or where it had maybe broke from another point. Ive tried to identify it by its color from the pages I printed off but nothing matches up. Does anyone know if there is a color code diagram for the wiring ?I'm not sure what else to do as of now.
537ONN
Quote Reply
Posted: 04-April-2016 at 7:05AM |
Hey everyone, Ive been outta the loop on working on my Torino, been busy with other projects but now Im back on it. So in doing some more trouble shooting I see that when I turn the key switch back to accessory or back towards me that the fuel gauge goes to full but the temp gauge stays to the left. Does this mean it could be something in the ignition switch ? But when I turn it to the start position both the gauges still go all the way over. Does anyone know of any ground points I could check that may be affecting this?
Quote Reply
Posted: 04-April-2016 at 2:25PM |
not sure if you already did his or not but, have your old cluster and one at a time trace the circuit along the printed part to the plug area there will be several ones to the gauges that are connected through the circuit those are the positive power from the key then the other stud from each gauge will be the negative with will go to the sender for each gauge ...oil,water, fuel, they get their ground through the sender for each individually and amount of ground is controlled by the sender to make the gauge read appropriately. you'll need to trace each circuit for both clusters and see if a wire will need swapped in the plug for the new cluster to be correct! i think i had to swap 3 wires? also some sport clusters had the gauges in different locations that could cause issues so that's why i say to trace each circuit one at a time and make a diagram to refer to as it can get mind boggling at times
fordpower
Joined: 02-September-2010 Location: willseyville,ny Status: Offline Points: 1807 |
Quote Reply
Posted: 05-April-2016 at 1:33AM |
I just figured it was a ford thing. My dash would be lit one time and next time only half.Now since the switch burned up nothing even with new switch.
537ONN
Quote Reply
Posted: 05-April-2016 at 1:50AM |
I hear ya , I found a lot of my trouble with the dash lights is the twist sockets. I pulled all of them and cleaned the contacts and adjusted them to put more pressure on the contact foil and they are working now. My issue with my temp fuel gauge is the same with either cluster I put in. Plus I keep blowing the rear passenger tail light bulb every so often. Im sure I have a ground issue I just don't know where. I guess Ill start disconnecting grounds and see what happens with the fuel/temp guage.
Quote Reply
Posted: 05-April-2016 at 2:47AM |
check along the wiring in the trunk there are a couple of grounds there
n2fordwagons
Joined: 20-July-2013 Location: GA Status: Offline Points: 2268 |
Quote Reply
Posted: 05-April-2016 at 3:05AM |
I have a similar issue with my '76 Montego with standard cluster. At first, I thought maybe my car was running hot. A couple of summers ago, I noticed my temp gauge creeping up. But, I wasn't having any other typical issues of a car running hot. Then, one day I noticed that every time my temp gauge would peg out, my fuel gauge was pegging out at the same time. It's very intermittent, and only lasts for maybe 5 - 10 minutes when it does happen. Not enough for me to mess with. I probably just need to add some reliable mechanical gauges under the dash for now.
Jeff
72 base Torino (modified) 72 Gran Torino Squire |
537ONN
Quote Reply
Posted: 05-April-2016 at 7:38AM |
Thanks Johnny, I have burnt out a couple of tail light bulbs too so that may be the area I need to start looking in. Of all the gauges I feel like those are the two most important ones. One other thing, my car didn't originally have a tach but has provisions to connect one. Does anyone ever notice what RPM they are at when running about 60mph? Im at about 22-25 rpm. I think I remember that being about normal for a 351W with FMX tranny.
75GranMan
Joined: 05-April-2011 Location: Colchester, CT Status: Offline Points: 1225 |
Quote Reply
Posted: 05-April-2016 at 3:03PM |
RPM will differ with axle ratio's. With 22-25 I'd guess you had around a 3.00 ratio?
Post Reply
| Tweet |
