  New Posts New Posts RSS Feed - Axle flange gasket
Axle flange gasket
bata747-8 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bata747-8 Quote  Post ReplyReply Direct Link To This Post Posted: 31-January-2015 at 6:23PM
Doesn't there exist a Small Bearing, Large Bearing and Torino Bearing? With the Torino Bearing being a modern version of the large bearing?
Forum Test Account
(formerly a spam bot account)
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquartlow Quote  Post ReplyReply Direct Link To This Post Posted: 01-February-2015 at 2:25AM
Amazing napa had three on the small beating gaskets on hand for my 72 housing. Ironically no stock on the big bearing flange gasket.
I'm just going to order a pile of them from rock auto and be done with it.
Note if you replace the nuts 3/8-24 thread.
Random notes for anyone else:
Axel flange gaskets
Fel-Pro
55065 large bearing
55035 small bearing
Napa Grover stocks
2301 rear axle gasket set felpro
55074 rear axle gasket felpro
CE – 9007B dif gasket Currie
3/8-24 nut
3/8" crush washer
CE – 5014 Currie track lock clutch pack
  Thumbs Up   Great info for future reference!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 01-February-2015 at 3:35AM
I've looked it up on the 'net, you'll find YES and NO YOU"RE CRAZY
I'm pretty sure there are 3 different bearings retainer plate bolt patterns
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 01-February-2015 at 4:45PM
Three? I'm only aware in the 72-73 and the late '73 and up big bearing.
Other note: buy a harbor freight transmission Jack. Makes doing a swap a safe proposition over using a floor Jack...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 01-February-2015 at 5:01PM
I'm finding 3, small, old big, and new big (torino)
Admin of "The Org"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GranTorinoSport Quote  Post ReplyReply Direct Link To This Post Posted: 01-February-2015 at 5:02PM
Swap of an entire axle assembly?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 02-February-2015 at 7:34AM
No just the chunk. About killed myself when I was lifting my spare carrier and it rolled on me but I caught it in time. I was being lazy and left my 3.50 chunk on my Trans jack.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 02-February-2015 at 7:36AM
As far as the bearing I'm only thinking of the common reference of Torino small or torino big bearing.
I'm assuming the other is for maybe truck 9"?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 02-February-2015 at 10:48AM
 8" and midsize car 9" got the small bearing until about 73-74, fullsize cars and trucks got the big bearing, around 74, they went to the "Torino" bearing (new big bearing)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 11-February-2015 at 6:54AM
Anyone have the timken wheel bearing part numbers for the 72-73 and 74-76 housings?
I want to replace my oem ford big bearing on my 76 housing.
For the time being I need to replace my small bearing 9" wheel bearing but tiring to make sure the lock ring is correct.
Fyi wheel bearing on 72-73 local parts stores are shown as obsolete not in the system.
Talk about bs
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 11-February-2015 at 7:15AM
I am running by my machine shop today and find out the 1 piece unit he used on mine!
Will post it later!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 06-March-2015 at 7:18PM
Note: don't try to think you are a smart person by hammering on two of the small lock rings in place of the original one.
interference issues.
Had new wheel bearings, and ended up having my original lock ring reused. Machine shop said no concerns, she's locked in place now.
