Wire harness retainer |
Author | |||||||||
75GranMan
Posted: 17-September-2014 at 3:14PM |
aquartlow
Have you tried National Parts Depot? They have quite a few parts that will work on our rides.
75GranMan
I tried NPD, either they don't have them or I couldn't find it on their site.
aquartlow
Here is a place that has plenty of wiring options, including clips, retainers and such. http://www.clipsandfasteners.com/Clips_s/219.htm
Here are a couple of options, though not a perfect match or for a concours restoration, these should work for your wiring needs. or Hopefully either one of these is an option for you. It is sad that there isn't any more options/support with the small parts for our rides. You either have to "make do" with 35-40+ year old parts or use an un-original part and make it "fit/work". Good luck. Todd
DLW
Member Joined: 09-January-2012 Location: Laurel, MS Status: Offline Points: 70 |
these might work?? not sure of specs / size. Original wire loom clip
Edited by DLW - 18-September-2014 at 6:20AM |
72sport
Senior Member Joined: 22-October-2006 Location: Wisconsin Status: Offline Points: 614 |
It says in jacks comments that black ones are reproduced. They are probably considerably cheaper.
Tom
1972 Gran Torino Sport 4Spd 1974 Montego wagon "GT" with GT hood, correct buckets seats, console, and floor shift 2013 Focus 5 speed- Daily driver |
TV 2M8O
Senior Member Joined: 20-September-2006 Location: Southern Ohio Status: Offline Points: 2052 |
I ran across some similar harness mounts a while back by accident. They were VERY close to what we need but not exact. I'll have to dig thru some of my reference material and see if I printed off the info.
dave302
I have found a similar type of clip, like in the picture below. The seller is selling 25 of them for $20.59 with free shipping. Maybe you can modify these clips so that they will be correct for your application.
Size:3/8” x 2-1/2”, Stem Length: 1/2", Fits into 1/4" hole. To see them click here.
Edited by dave302 - 18-September-2014 at 1:11PM |
75GranMan
Anybody have an old harness that they could part with a couple of nice clips? I won't be able to use the white color because of there location. Still searching for the black repo ones...
Billy C
Senior Member Joined: 10-February-2010 Location: Pittsburgh, PA Status: Offline Points: 948 |
That's almost a dollar a clip! anyways.. I will look through my bin of wiring harnesses for you and see if I can find some I didn't destroy on removal.
-Billy Conturo
dave302
I had just tried to find the black colored reproduction wire harness retainer clips, but i could not find them. But i will try to keep looking for them. If you are not able to find the correct retainers for your application, there is a seller that is offering a quantity of 10 wire harness retainers for $3.37 plus $2.95 for shipping. The measurements are: 3/8" wide X 1-7/16" long and they have a 9/32" diameter, with a 7/16" long stem. They are made of white nylon, but maybe you can paint them black.
In this next auction this same seller claims that these same exact size retainers will fit a 1972 ford ranchero, but this auction is for a quantity of 20 retainers for $6.30 plus $2.95 for shipping. Edited by dave302 - 19-September-2014 at 9:29AM |
TV 2M8O
Here are a couple pictures of the clip removed from the harness & wrapping........
Still diggin on my end! |
john, you are needing those for the under hood section? i can look on my harness to see if a couple are good, i'm going to go through my harness and eliminate any unnecessary wires and probably extend it some to route it back behind the fenders to clean up that wiring mess (out of sight, out of mind)
75GranMan
John, looks like Joe already has them almost ready to ship....Unless he's just teasing me! HaHaHaHa
Seriously,If you can find and can spare a couple of good ones let me know. Adding my MSD ignition and Wigwag to the harness,I broke three of them. all the extras I had are to brittle to use.
75GranMan
Dave, thanks for your efforts/ computer/ auto knowledge! I enjoy the chase of finding OEM correct stuff for my car. I do have the white style retainers from my stint at my Ford Dealership.
dave302
Your Welcome.
TV 2M8O
OK guys, getting close. I received this sample this afternoon.....
This is as close to the original style that I can find. It's missing the hole and slot in each arm for securing a single wire without the need of tape (which could easily be added in those rare instances) but I think it will work well buried in a harness covered with electrical tape and loom wrap. It even includes the foam rubber washer that may help to waterproof the mount along the front wheel houses! Damn, now I need to find my original to do an actual side by side comparison! LOL, glad to know I ain't the only one who misplaces parts! Pricing will follow in a day or two and it looks like I'll have to buy about 500pcs minimum, so everyone please let me know how many you need! More info and pics to follow once I get pricing... and find my darn pieces!!
Edited by TV 2M8O - 20-October-2014 at 11:34AM |
72 RS 351
Those look good Joe. Try to estimate how many of them are used in various parts of the cars. That might help to figure out how many the rest of us could need.
TV 2M8O
OK, I found my OEM harness retainer and here are some side by side comparisons. Here is as purchased compared to EOM (rubber sealing washer removed)....
and here is the purchased clip with washer flange & length quick trimmed to match OEM (no wire holes or slots added).... Still awaiting cost to import 500/1000pcs from China..... Will advise once I've gotten pricing.
75GranMan
Joe, looks good, try installing them is their respected holes before you wrap the harness...The ones I used were a little to big to snap into the holes.They looked just right but I had to shave the base on the shank as so it would fit the hole.
TV 2M8O
OK guys, I've finally gotten pricing back on the sample clips above. I HAVE TO BUY A MINIMUM OF 500PCS (standard package size) and have them imported. Anyone interested in getting some of these for 1.25 each (+s&h)? Let me know what you need and I'll reserve them for you.......Once I get them in, I'll make up packs of 10/25/50/100pcs and get shipping prices via USPS.
Edited by TV 2M8O - 10-November-2019 at 9:21AM |
TV 2M8O
LAST CALL BEFORE EBAY... ORDER YOURS TODAY!
TV 2M8O
JUST A REMINDER THAT I STILL HAVE A FEW OF THESE LEFT..............
PM sent
