  New Posts New Posts RSS Feed - Door compatibility
Door compatibility
smhj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smhj Quote  Post ReplyReply Direct Link To This Post Topic: Door compatibility
    Posted: 02-December-2014 at 10:01AM
The bottom of the Montego door is toast. I was wondering what other doors I could use as a transplant.
73MONTEGO
dave302 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2014 at 10:39AM
I am almost positive that the 1974, 1975 and 1976 Cougar and ford gran Torino ELITE (NOT THE REGULAR GRAN TORINO/NON-ELITE'S) lower doors are the same.
The regular 1972 through 1976 ranchero, torino and gran torino "NON-ELITE" lower doors are probably different. So it will probably have to be a 1974-1976 cougar or gran torino ELITE lower door.
It might also be possible that the 1977, 1978 and 1979 thunderbird, ranchero, cougar and LTD II (lower doors) are similar, but i am not 100% sure about this part/subject. Hopefully one of the other members will know for sure.
Edited by dave302 - 02-December-2014 at 11:05AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2014 at 10:41AM
What side?
13 Taurus SHO "Mr Pig"
smhj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smhj Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2014 at 10:44AM
Pass Side.
Side note how did I become a Senior Member? Save that for the smarter ones.
73MONTEGO
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2014 at 10:46AM
You have now passed your 200 points, which automatically makes you a senior member.
Edited by dave302 - 02-December-2014 at 10:47AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2014 at 11:28AM
No luck. I have a left side door skin.
n2fordwagons View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n2fordwagons Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2014 at 12:40PM
I have a solid 77-79 Ranchero door if it will work.
Jeff
71 Torino Brougham
72 Gran Torino Squire
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2014 at 2:16PM
i do know the gran torino's are different, but not a 100% on the others but i think dave is right, they do look right as far as body lines???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2014 at 2:37PM
Dan the Ranchero man's Ranchero has a Montego clip on it, and it lines up with the doors fine. The whole door will not interchange, as the 72-76 window line lifts up near the back of the doors, but the bottom should be the same...
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2014 at 3:24PM
Yes, there is a picture below of a 1974 gran torino.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2014 at 3:29PM
^^^ damn, i could use some parts off of that car!!!Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2014 at 3:34PM
It might be possible to use the extreme lower (very low) door portion from a 1972, 1973, 1974, 1975 or 1976 torino, non-elite gran torino or ranchero. I am not 100% sure about this though. Hopefully one of the other members will know if this is true or not.
But as you can see from the pictures, the lower-middle to upper doors are different than the non-elite gran torino's, the '72 through '76 ranchero's and base model torino's . There is a picture below of a 1974 montego door.
Edited by dave302 - 03-December-2014 at 12:20PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2014 at 3:37PM
There is a picture below of a 1974 gran torino elite.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2014 at 3:39PM
There is a picture below of a 1974 cougar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2014 at 3:43PM
There is a picture below of a 1977 through 1979 ranchero door, as you can see the lower to middle portions of the door are very similar to the 74-76 cougar, montego and gran torino elite. But the upper part of the door is different than them.
Edited by dave302 - 02-December-2014 at 3:48PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2014 at 3:47PM
There are two pictures below of dan's 1978 ranchero/montego.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave302 Quote  Post ReplyReply Direct Link To This Post Posted: 02-December-2014 at 3:49PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 03-December-2014 at 2:41AM
I'm betting that the lower section would work. Ford wasn't too creative back then and re-used a lot of tooling.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lynchster Quote  Post ReplyReply Direct Link To This Post Posted: 03-December-2014 at 11:55AM
Those pictures were actually pretty helpful. I had intended to use this doorskin on my old Ranchero but turns out it's for the coupes.
