  New Posts New Posts RSS Feed - 1972 Gran Torino Trunk Weather Stripping Metal
Richo View Drop Down
Brand New Member
Brand New Member
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richo Quote  Post ReplyReply Direct Link To This Post Topic: 1972 Gran Torino Trunk Weather Stripping Metal
    Posted: 24-March-2015 at 4:56AM
Do any of the Gran Torino parts companies sell the metal that goes beneath the trunk weather stripping? This area is pretty porous with rust damage. Thank you!
fordismyboss View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fordismyboss Quote  Post ReplyReply Direct Link To This Post Posted: 08-November-2015 at 4:39PM
My 72 GTS has the same issue. Any info out thee to share?
I'm currently looking for a donor car for the upper drip channel of the trunk.
Anyone ever repair this area by fabricating a new channel?
Montego01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Montego01 Quote  Post ReplyReply Direct Link To This Post Posted: 09-November-2015 at 6:04AM
If you don't have a donor car, the only way I can think of is to us the flexible edge patch panels.
I used this on my flares and it worked great. You'll have to weld these in, then duraglass (or equivalent) them to sculpt if the way you want it, then coat it with bondo.
They come in 3/4" and 3" I believe.
You can Google
Patch Repair Metal Panels flexible edge
Scott
72 Montego GT 429 build thread
1966 Chevy C10
1973 Montego MX
2004 Bonneville GXP
NorthElite View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NorthElite Quote  Post ReplyReply Direct Link To This Post Posted: 10-November-2015 at 7:22AM
I need to make it too and I don't know yet how I going to fix it. Maybe I use small metal curving machine to make my lower and left side drip channel of the trunk. My upper channel and right side is OK.
Some part of the channel is made of two pieces and spot welded together. Lower corners are difficult to do and maybe I go with two pieces in corners too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eliteman76 Quote  Post ReplyReply Direct Link To This Post Posted: 10-January-2017 at 3:11AM
Pictures are helpful.
In my case I bought a parts car just to get the steel I needed.
