fuse no1 low volts |
scottys torino
New Member Joined: 24-April-2015 Location: okotoks Status: Offline Points: 3 |
Posted: 24-April-2015 at 3:07PM |
Hi everyone just bought a 76 Gran Torino,I am currently sorting all the electrical ,car has sat for years outside.Fuse number 1 has only 3 volts were does the supply come from,I can't find it on any of my schematics.Does it come from light/dimmer switch? Thank you for any help..Mark
i'm not sure which fuse you are referring to? is it labeled? is it powered all the time, or only with the key on, or only with the lights on? are you getting low voltage on both sides of the fuse?
scottys torino
Thank you for reply ,fuse is 4 amp instrument panel illumination lamps.Only 3 volts on both sides fluctuates slightly too.
scottys torino
4 amp fuse instrument panel illumination lamps 3 volts both sides
my manual (book) doesn't have the schematic for the wiring
do you get a different reading when you rotate the light switch left to right? dash light dimmer, i think the power goes through the fuse first then through the dimmer then to the dash lights, but i could be wrong? if that's not the case then i'd say there is some corrosion or other bad contact supplying that circuit. i'll keep looking for a schematic... |
aquartlow
If you remove the fuse is there still only 3 volts on the supply side? More that likely corrosion is the culprit. I have a '79 electrical/vacuum trouble shooting manual as well as wiring diagrams that shows what wire supplies power for each circuit in the fuse panel, if needed. I realize not the correct year, but could give the correct info. Todd
