  New Posts New Posts RSS Feed - What will fit a fastback from a coupe
peanut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote peanut Quote  Post ReplyReply Direct Link To This Post Topic: What will fit a fastback from a coupe
    Posted: 20-May-2015 at 1:01PM
Will the doors, quarters and frame fit from a  coupe, fit a fastback?
Post Options Post Options   Thanks (0) Thanks(0)   Quote GTW Quote  Post ReplyReply Direct Link To This Post Posted: 20-May-2015 at 1:14PM
Doors and frame, yes. Maybe lower quarters below the actual roof itself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 21-May-2015 at 2:04AM
Door glass will need to be swapped out - Sportroof and Formal have different door glass
1/4 side glass is different
Trunk lid will interchange
Interior rear panels are different
Parcel tray is different
Inner body bracing from the rear seat-back is different
Rear glass is different
From mid-bodyline down on 1/4 panels is the same (mid-bodyline up is completely different)
Bumpers/fenders/valences are the same
Post Options Post Options   Thanks (0) Thanks(0)   Quote peanut Quote  Post ReplyReply Direct Link To This Post Posted: 22-May-2015 at 9:44AM
Thanks for the info. I found a 1972 torino sport fastback for $2500. It needs doors, quarters, a small rust whole in the frame and it does not run.  For additional $3500 he will include a pretty solid running coupe if I buy the fastback. The coupe runs and drives and only has a little rust in the lower quarters which he is throwing a set of new quarters in the deal.  Trying to decide if the coupe would be worth buying to strip.
rough_72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rough_72 Quote  Post ReplyReply Direct Link To This Post Posted: 22-May-2015 at 11:34AM
Buy it all and build the coupe. Sounds like the fast back is rough. Just my opinion
AJ McKenna
Post Options Post Options   Thanks (0) Thanks(0)   Quote peanut Quote  Post ReplyReply Direct Link To This Post Posted: 22-May-2015 at 11:51AM
Rusty yes but not beyond repair.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 22-May-2015 at 12:54PM
would like to see pics.
Prices depend on what they are and how much work they need.
Hard for anyone here to give you any thoughts without pics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote peanut Quote  Post ReplyReply Direct Link To This Post Posted: 22-May-2015 at 1:15PM
Don't own either car yet , and the cars are not posted anywhere for sale. I was just wonder if buying the coupe made sense because I was unsure what would fit.  If I get them I will post them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r Quote  Post ReplyReply Direct Link To This Post Posted: 22-May-2015 at 2:14PM
Paying that much for the coupe just to transfer any parts over to the Sport is not worth it.
