  New Posts New Posts RSS Feed - Side View Mirror Question
GoldFinger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GoldFinger Quote  Post ReplyReply Direct Link To This Post Topic: Side View Mirror Question
    Posted: 17-November-2015 at 1:11PM
Hello,
My passenger side side view mirror glass jumps aroundand it does not stay in place, is there any way to tighten the glass so it doesn't move around, since it's so loose?
if not, I guess I have to buy a new side view mirror right?
DARE to be DIFFERENT!!
       73 GTS
75GranMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75GranMan Quote  Post ReplyReply Direct Link To This Post Posted: 17-November-2015 at 1:55PM
Ck ebay, someone has the part listed. If I find the link i'll attach it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 17-November-2015 at 2:19PM
tilt the glass and look in behind there, there is a screw in there that holds that assembly into the housing. or is yours a passenger side remote? not sure about those
Post Options Post Options   Thanks (0) Thanks(0)   Quote GoldFinger Quote  Post ReplyReply Direct Link To This Post Posted: 17-November-2015 at 2:24PM
Hey what are you talking about John? Are you talking about the mirror? Yeah I see those are all the time on eBay, but I was hoping to just fix the mirror.
Edited by GoldFinger - 17-November-2015 at 2:25PM
       73 GTS
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75GranMan Quote  Post ReplyReply Direct Link To This Post Posted: 17-November-2015 at 2:24PM
Post Options Post Options   Thanks (0) Thanks(0)   Quote GoldFinger Quote  Post ReplyReply Direct Link To This Post Posted: 17-November-2015 at 2:27PM
http://www.ebay.com/itm/1974-1979-FORD-Sport-Mirror-Replacement-Pivot-Torino-Cougar-R-A-R-E-/321921760394?hash=item4af4083c8a:g:PoYAAOSwPcVVlEO3&vxp=mtr
 Try this.
Oh, okay I see. But it doesn't say it will work for 73's...
Thanks for your help!
       73 GTS
Post Options Post Options   Thanks (0) Thanks(0)   Quote GoldFinger Quote  Post ReplyReply Direct Link To This Post Posted: 17-November-2015 at 2:29PM
No Cali'John mine is not a remote passenger mirror.I will work on this task tomorrow, thanks!
       73 GTS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 18-November-2015 at 9:05AM
or, Take the knob/lever out of the mounting hole. Put a zip-tie around the 3 cables up near the lever (where they are separate, right before the lever) and pull it tight so it pulls the 3 cables/housings together. It worked for me, but the mirror is still too damn small.
