  New Posts New Posts RSS Feed - Cobra Jet - 71 Starting problems
JOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JOH Quote  Post ReplyReply Direct Link To This Post Topic: Cobra Jet - 71 Starting problems
    Posted: 05-June-2016 at 11:18PM
Hi. I have a frustrating problem on my -71 Torino. Suddenly it wont turn - as if there is no power on the battery. It doesnt even help using jumper cables.
After a while - like half an hour, eveything is OK?
The battery seem to be fine, but I havent made any diagnostical measurings.
Any suggestions?
JOH
Regul8r 2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Regul8r 2 Quote  Post ReplyReply Direct Link To This Post Posted: 12-June-2016 at 12:09PM
WELCOME to the Family!
Your account should be activated now.
Sounds like you have a bad starter, bad starter wires or connections. Could be the starter solenoid/relay too.
Owner- www.CaNDeCustoms.com
JOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JOH Quote  Post ReplyReply Direct Link To This Post Posted: 13-June-2016 at 9:24PM
Hi, and thanks.
OK, I have been suspecting this relay - maybe I should start with this.
Thanks!!
Jan
JOH
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 14-June-2016 at 12:32PM
Jump over the solenoid. if it cranks, solenoid is shot.
Use one side (red or black) of the jumper.
connect one side to the battery terminal that feeds the solenoid and tap the other against the starter side of the solenoid. Careful, it will spark.
(Redneck Ford trick, you can also jump the little wire to the hot side of the solenoid and do the starter trick to start the car without keys)
JOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JOH Quote  Post ReplyReply Direct Link To This Post Posted: 14-June-2016 at 7:45PM
Thanks Randy, and yes - this made more sense with the grympy old man voice!
I will try this trick. I have a strong suspection to this solenoid.
Thanks again!
JOH
