  New Posts New Posts RSS Feed - Ghost Q-Ship
Ghost Q-Ship
gentrysgarage View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gentrysgarage Quote  Post ReplyReply Direct Link To This Post Posted: 04-April-2017 at 12:09PM
Thanks Guys, I was curious, It seems like the buckets are original to the car, then someone put in a hole and 4 speed and lastly bought a console and a shifter that came up with the Titanic teacups!
  Looks like the ignition setup you chose should work well.  Looks similar to Todd's setup we discussed in the ignition thread.
I did a ton of research and found 2 magazine articles plus lots of supporting webpages didn't see the ignition thread but will go looking for it.
thad, i just sent your parts out a few minutes ago!
Thanks!
the window rollers...are you talking about the plastic roller for the window track? they are riveted but the replacements bolt into the hole or are you talking about the gear part of the regulator? i have a nice passenger side regulator available....
The white plastic pieces are what I need to get. The one on the crank arm is still in one piece, but the 2 for the guide are chipped and broken I'd rather just replace it now while it's all apart..a pre-emptive strike so to speak!
Edited by gentrysgarage - 04-April-2017 at 12:36PM
Post Options Post Options   Thanks (1) Thanks(1)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 04-April-2017 at 12:22PM
oh the square plastic things? i have several how many do you need?i also have a couple new roller pieces as well (had to buy a kit of 4 just to get one for my car)
74 CORVETTE COUPE CUSTOM
Post Options Post Options   Thanks (0) Thanks(0)   Quote gentrysgarage Quote  Post ReplyReply Direct Link To This Post Posted: 04-April-2017 at 12:39PM
I am going to replace all of them with new ones. The fronts seem to be different but haven't gotten to them yet.
Thanks
Post Options Post Options   Thanks (1) Thanks(1)   Quote 72FordGTS Quote  Post ReplyReply Direct Link To This Post Posted: 04-April-2017 at 12:51PM
Here is the ignition thread.  It talks about a few different options, including your setup (near the end of the thread).
Randy is correct about the tilt wheel, but this wasn't an option in 1972.  Didn't become available until 1974.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gentrysgarage Quote  Post ReplyReply Direct Link To This Post Posted: 07-April-2017 at 4:35PM
Thanks Vince for the link.
Ok been working on the Torino today and have some questions:
It seems the front windows have sguare rollers connected to the window regulators, the rear are round and broken, do the square ones supercede the round ones and does anybody have the right part number (I have seen 2 different numbers posted for the 72 Torino)
I do need at least 2 of these rollers that go on the guides in the rear.
I still haven't gotten to the front windows, but probably will need the 2 guide teflons.
As the original grease became almost an epoxy any suggestions on a good grease?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gentrysgarage Quote  Post ReplyReply Direct Link To This Post Posted: 08-April-2017 at 12:25PM
I GOT the parts THANKS!Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 08-April-2017 at 3:09PM
awesome! let me know if you need anything else... i'm out there still disassembling parts nowConfused
Post Options Post Options   Thanks (0) Thanks(0)   Quote gentrysgarage Quote  Post ReplyReply Direct Link To This Post Posted: 17-April-2017 at 8:25AM
Thanks to John and eBay I have a full set of window regulator rollers in transit, still need the widow guide rollers pictured previously. It was a Great Eater Weekend, starting with a real thrash on Good Friday.
Ready for primer finally
The proper stance to go about stripping inner fenderwells
Then Saturday night
So the order going forward...
Prime doors and hinges
Basecoat/topcoat/clear jambs (doors,hinges and body)/window channels/cowl top
install doors
install roof insulation/headliner and front and rear windshields
side windows
firewall pad
steering column/AC/Dash bracketry
to be contined.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 17-April-2017 at 5:43PM
hell yeah! looking good Big smile are you going to use seam sealer? also i did the whole under side and the wheelwells and the inside pans and the trunk with bed liner!!! Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote changinlatitudes Quote  Post ReplyReply Direct Link To This Post Posted: 18-April-2017 at 12:39AM
Coming along great!
Matt
1972 Montego MX
2003 Mercury Marauder 300A
2015 Honda Civic Coupe
2016 Ford Fusion Titanium
Post Options Post Options   Thanks (0) Thanks(0)   Quote gentrysgarage Quote  Post ReplyReply Direct Link To This Post Posted: 18-April-2017 at 6:18AM
Thanks for the kind words guyz, its been a battle but it has just begun...she wants it done in a month Stern Smile ...we'll see
I pulled all the seam sealer from the rear wheelwells forward as the tar had hardened and was getting a very slight browning on the bare metal underneath, I amm replacing it. I wanted to get a coat of primer sealer on all the metal then the seam sealer, then the black basecoat, then the bedliner in the center floor,roof, trunk and wheelwels. I would like to paint the underside...but with the missus' imposed deadline that is gonna wait! LOL!
This page was generated in 0.079 seconds.
