  New Posts New Posts RSS Feed - gpd294's Tribute Torino Wagon Restoration
 Post Reply Post Reply Page  <1 13141516>
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 15-January-2016 at 4:23AM
That looks correct. I know you are wanting to keep it original looking, but you can get a 110 amp GM chrome 1 wire alternator for $68. Eliminates the pesky Ford voltage regulator, cleaner install, and no more pulsing lights. I have converted several of my old Fords to that with excellent results ('68 F100, '67 LTD, '65 Falcon wagon, 72 Torin0, '76 F100). Just another option to explore, and you can get a lifetime warranty non-chrome unit from Autozone or Advance for even less.
1972 GTSquire Wagon
1976 Torino (2)
Post Options Post Options   Thanks (0) Thanks(0)   Quote gpd294 Quote  Post ReplyReply Direct Link To This Post Posted: 15-January-2016 at 4:26AM
Hey Joe, can ya send me a link to the chrome GM option please? I didn't know they interchange...Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 15-January-2016 at 6:06AM
Carlos, there is a small bit of wiring work involved, but it really cleans up the engine compartment, and simplifies everything. When done, it looks like it came from the factory. Here is just one Ebay site, but many more are out there.
http://www.ebay.com/sch/i.html?_nkw=100+amp+chrome+alternator
There are 100, 110 amp versions among others. 110 amps with an internal regulator will take care of your current electrical needs as well as a good sound system - and so much more simple.
Several of the members on here have done this with excellent results.
Edited by unlovedford - 15-January-2016 at 6:07AM
1972 GTSquire Wagon
1976 Torino (2)
Post Options Post Options   Thanks (0) Thanks(0)   Quote californiajohnny Quote  Post ReplyReply Direct Link To This Post Posted: 15-January-2016 at 9:27AM
carlos, joe's right about the gm 10si alternators i have one on my torino and most all of my other cars too! if you go with a 3 wire gm i can tell you how to wire it! super simple!! but here is a new chrome 1 wire for a ford and it looks to be gm 10si with a modified ford front mounting case! (that would bolt on the same as you have. the stock gm case would need to be drilled out for the ford 7/16" long bolt FYI) but this one would bolt right on, looks like it doesn't come with the fan/pulley, but if you get one without, let me know i have a brand new chrome fan/pulley for a ford or gm alternator---yours for the ride!!Big smile
 http://www.ebay.com/itm/Ford-1-Wire-Alternator-Chrome-100-Amp-302-351W-351C-390-429-460-100A-One-Wire-/111619125802?hash=item19fd04b22a:g:prAAAOSwr81UTEz6&vxp=mtr
74 CORVETTE COUPE CUSTOM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 15-January-2016 at 9:27AM
My recommendation would be to steer away from the chrome version (chrome hold in lots of heat) thus shorting the life of the unit. Get the NON chrome and you will be good to go!
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 15-January-2016 at 9:31AM
Agreed on both of the above comments.
1972 GTSquire Wagon
1976 Torino (2)
Post Options Post Options   Thanks (0) Thanks(0)   Quote gpd294 Quote  Post ReplyReply Direct Link To This Post Posted: 20-January-2016 at 6:12AM
How about a polished version??? Would that be OK, or should I just go with the standard case?
I'm still contemplating the GM one wire as well... Wink
Edited by gpd294 - 20-January-2016 at 6:12AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 20-January-2016 at 9:13AM
Polished would be fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gpd294 Quote  Post ReplyReply Direct Link To This Post Posted: 13-May-2016 at 8:54AM
I took the wagon out last weekend for a rather lengthy drive and on the way back home I blew the A/C-Heat 30A fuse. I was driving when all of a sudden the A/C fan quit blowing. I got home and changed it out and it seemed to work again. Well today I stopped by the house at lunch time and brought the wagon in to work to check to see if that was just a simple fix. Well not so much....Dead
I'm driving with the A/C on and all of a sudden I can hear the vent flapper switching around down by the passenger side floorboard. It sounds like the flapper is just cycling without the switch being moved.
Any ideas where I should start to look to find the culprit???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 13-May-2016 at 11:08AM
 Does it flap around when you hit the throttle? Check for a vacuum leak in the controller switch, related hoses, or the actuator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gpd294 Quote  Post ReplyReply Direct Link To This Post Posted: 16-May-2016 at 2:52AM
I noticed it ALL the time. I looked at it briefly this weekend and I may have something stuck in the squirrel cage as well.
I'm thinking I am gonna replace the fan motor and squirrel cage all at the same time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gpd294 Quote  Post ReplyReply Direct Link To This Post Posted: 13-June-2016 at 2:51AM
Hey Guys, just a quick update. I got my alternator upgraded to a newer style one wire alternator, which eliminates the regulator. I went with the natural steel case to avoid any extra heat. Also had the blower motor replaced and now the wagon's A/C blows a lil stronger!
A quick review of the LED Halo headlights. They are working great, but two of them have cracked lenses already. Something about the glass they use isn't as strong as maybe it should be. I have already ordered replacements, but was wondering if anyone else is having the same issue. Confused
Last thing is I went over to Staples (Office supply store) and had them print the Wagon Jack instructions on some peel and stick paper and I installed it behind the spare cover.
Hope to see some of you Guys tomorrow in Grand Prairie, TX @ the Hot Rod Power Tour stop!  Beer
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 13-June-2016 at 10:05AM
One of the halo headlights on mine seems to always fog up during a temp drop. I have tried to open it up and let it dry out but doesn't seem to make a difference. Otherwise they work fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gpd294 Quote  Post ReplyReply Direct Link To This Post Posted: 22-July-2016 at 2:55AM
After my mechanic replaced the A/C blower motor on my wagon, apparently the cardboard glove box took a beating. It was already pretty deteriorated, so I went ahead and ordered a new one (Re-pop) from Ebay. (Class-Tech-Cars). I thought it was a lil pricey @ $45.00, but its a direct replacement. It's made exactly the same and was an easy 4 screw replacement!
Edited by gpd294 - 22-July-2016 at 2:56AM
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan the ranchero man Quote  Post ReplyReply Direct Link To This Post Posted: 23-July-2016 at 1:37AM
The Key is that it fits/works like it should. I agree $45 is a bit on the high side, BUT if you paid $30 and didn't fit and had to be modified to fit I would think that would be worse. I bought a set of window and door seals from Dearborn classics for the 74 ranchero and those things are awful! Paid a lot of money for seals that had to be shaved to fit on the door side and the window seals always leak and create wind noise when the windows are closed. I would gladly pay a little extra for a great fit and function. Glad to see your stuff is working as it should.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rockatansky Quote  Post ReplyReply Direct Link To This Post Posted: 23-July-2016 at 3:59AM
I did a slice & dice of 2 glove inserts, I cut them to overlay & fit together real nice & glued them together
yeah I'm a cheap Censored but it's dark in there & who's gonna see?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Bird Quote  Post ReplyReply Direct Link To This Post Posted: 23-July-2016 at 8:11AM
Now, the inside of the trunk, that's a different story. The hostages might see that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gpd294 Quote  Post ReplyReply Direct Link To This Post Posted: 30-May-2017 at 4:55AM
I took the wagon out to a local show this past weekend and won Best in Class 70's car. My brother brought out my oldest brother's 72 Chevy PU. (If yall remember my oldest brother passed away this past February, so it was nice to see his truck participating in a show for the 1st time after he got it up and running again.)
Clap
R.I.P. David!
Edited by gpd294 - 30-May-2017 at 4:56AM
72GTS351CJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 72GTS351CJ Quote  Post ReplyReply Direct Link To This Post Posted: 30-May-2017 at 6:31AM
Congrats on the award! That wagon is looking sharp. I spent many miles in the 3rd roweek and enjoyed every minute. Sorry about your older brother
72GTS Clint Eastwood Special
Post Options Post Options   Thanks (0) Thanks(0)   Quote unlovedford Quote  Post ReplyReply Direct Link To This Post Posted: 30-May-2017 at 3:23PM
Carlos, so sorry to hear about your brother.
Congratulations on the award!
1972 GTSquire Wagon
1976 Torino (2)
